Question about Ricoh Aficio Mp C6501 Sp
Replace drum for ricoh c6501 - Ricoh Aficio Mp C6501 Sp
2 Suggested Answers
SOURCE: Ricoh Aficio Colour MP C6501 giving me "SENDER NOT
usertool > system Settings > File Transfer > next >next Auto Specify sender name > turn it on hit ok.
Also check Administrators email has been programmed in File Transfer
Posted on Nov 16, 2010
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Error sc300 on Ricoh mpc 7500. i replaced the drum unit and its fine but after two weeks the error came up again
The error code you gave shows several possibilities for your issue:
Drum charge corona wire, The output of the charge corona wire of the black PCU is abnormal.
Causes
• CGB power pack connection loose, broken defective • Check CGB power pack connection to BCU • CGB power pack defective • BCU defective • Replace OPC drum
Of the five possibilities above, replacing the drum is the most likely cause. Since you only had your drum for a couple of weeks I would take it back to where you purchased it and ask for replacement. Sometimes you get a bad drum out of the box from the manufacturer. It happens. If the same error code pops up again, I recommend you call your local Ricoh dealer for further troubleshooting.
Aug 26, 2016 | Ricoh Aficio Office Equipment & Supplies
Konica minolta c6501 c-2840 error
Clean all three sensors that monitor the belt have to pull belt and drum section will be on the left hand side monitoring the belt. all thre have covers that open and close by solenoid but can be open with you fingers do not lean on the drum shaft best way to get to all three is from the right side with drum and belt section out DO NOT LEAN ON THE DRUM Shafts. to have small springs they can fall off.
Jul 04, 2014 | Konica Minolta Office Equipment & Supplies
C 2812 on c6501
Magenta drum potienial, remove the magenta drum and clean the small little tiny square on a chrome part near the front end of where the drum goes. if not then swap the sensor out with yellow or cyan and see if the code changes to a different drum if so replace it.
Feb 08, 2014 | Konica Minolta Office Equipment & Supplies
Ricoh Aficio Colour MP C6501 giving me "SENDER NOT SPECIFIED" while trying to scan and send to email. please help
Oct 02, 2010 | Ricoh Office Equipment & Supplies
SC387 error code on Ricoh
SC387 Drum potential
error
Cause
· Uneven charge
· Worn drum
· Defective potential
sensor
Try the following
1. Clean the charge corona unit or replace the charge
corona wire and grid plate.
2. Reinstall the drum.
3. Replace the drum if necessary.
4. Replace the potential sensor.
Let me know if you need any more assistance
May 08, 2010 | Ricoh Aficio Colour 3006 Color Copier
I have a problem with my Ricoh Aficio 2022sp. It leaves a black line when I copy or print anything.
Something around the drum need to be replaced. There are two ways to be done. Because Ricoh do not offer a replacement by parts around the drum unit for this machine by Ricoh you can only replace the hole drum unit. But as you say you have a problem with the drum cleaning blade, or in worse case the drum and the cleaning blade for the drum need to be replaced. So Katun offers a replacement by parts and by Katun is more cheap to be replaced. This is what is the problem, so on your hand is what are you gonna decide.
Dec 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Nov 16, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio Mp C6501 Sp Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
