Question about Bosch Nexxt 300 Series WFMC2201UC
How to remove front panel on WFMC2201UC - Bosch Nexxt 300 Series WFMC2201UC
Washer is leaking water out from underneath during cycle
Ours had a problem with water sloshing out of the soap cup during the cycle. The leak appeared under the left front. The fix was to remove the cup and just pour the soap into that section of the drawer. The only problem withthis is that you cannot add soap after you add the soap.
Sep 20, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Washing E-13 comes up
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc.
Good Luck.
Jul 06, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Our washer will not spin during any cycle
Have you checked the pump and filter are clear? bottom right flap on front panel to expose pump. Check the hoses are clear, particularly if it is connected under the sink, via a spigot connection. If the machine has good motor action, but not spinning effectively, it will more than likely be a drainage problem.
Jul 05, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
How do you open pump door?
The access panel on the lower front of the washer can be opened by prying up the lower side of it (near the small hole, I'm guessing repair guys have a special tool to do it), and at the same time twist the whole thing clockwise.
Do the reverse to put it back on.
May 05, 2010 | Bosch Nexxt 300 Series WFMC2201UC
I put a load of clothes in my bosh nexxt 300 washer, went out to the store and such come home to put the clothes in the dryer, the door is locked, no lights on the washer. The washer is plugged in and plug...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is for the WFMC6400, but it could help.
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and
locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch
assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch,
or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks!
Apr 24, 2010 | Bosch Nexxt 300 Series WFMC2201UC
The drum wouldnt spin
have you removed the rear access panel to check the drum drive belt and see if its broken
Mar 12, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Bosch washer WFMC2201UC/15 has E13 error and will not fill
Hi  hartselectri,
Check the drain hoses and pump That code is for a longer than normal drain if it did not drain it would not let you open the door, You need to clean the filter. Remove the circular panel on the front right put a little screw driver in the hole and twist the access panel will pop off. Then you will need to twist the handle of the filter and pull it out you will find what is stopping the unit from draining in there very common. Also have a lot of towels handy all the water in the unit will come out when you pull the filter.
Regards
R.K.
Sep 08, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Oct 27, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 Series WFMC2201UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
