Question about Oster OGB61102 Black Countertop Microwave 1.1 Cu Ft, 1000 Watts
Microwave oven keypad does not register - Oster OGB61102 Black Countertop Microwave 1.1 Cu Ft, 1000 Watts
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
Ge microwave oven key pad short circuited JVM 1540
see the next steps. God bless you
Oct 03, 2012 | GE JVM1850 1000 Watts Microwave Oven
Keypad 3 & 9 do not work on ge jes1290
The keypad control board must be replaced, cost can rival some microwaves.
Apr 17, 2012 | GE JES1290 Convection/Microwave Oven
Beeps twice upon releasing any button and does not do anything... What could cause this and is there a fix?
The problem is in the keypad control board, or smart board. Consideration should be given to replace the microwave oven, because the cost to repair can not be justified.
Apr 06, 2012 | Microwave Ovens
Doesn't register when you press a button/number. It will occasionally detect it, but it's few and far between
The keypad controller probably has a short, behind the pad is the microprocessor ic along with several parts mounted on a circuit board, the replacement cost is high and considering the price of a new microwave oven might be the best option.
Feb 12, 2011 | Microwave Ovens
GE microwave is unresponsive
I suspect the controller is a low-level microprocessor that may even have its own programmable chuck of memory on board to adapt to different models. Either the clock (for synchronizing the processor) is no longer running or the processor itself has failed.
I doubt if this board is considered repairable so figure on replacing it. It probably cost all of $5 to produce but likely in the upper two digits to buy.
Unfortunately, GE quality and that of their sources (they don't build much of it) has dropped drastically in the last decade.
Mar 28, 2010 | GE JVM1540DM Microwave Oven
F-6 showed up on my microwave window
self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "?" is displayed...
F6 ?Microwave Relay Failure: Check the microwave relay.
Jan 26, 2009 | Whirlpool MH7140XF Microwave Oven
Westinghouse WST3501 Microwave
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Aug 30, 2008 | Westinghouse WST3501 Microwave Oven
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Aug 21, 2007 | Emerson MW8108P Microwave Oven
Oster OGB61102 Black Countertop Microwave 1.1 Cu Ft, 1000 Watts Logo
12 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
