Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Engine starts then dies - Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Why did car die while driving on Interstate and will not start back up
When the engine dies all the lights on the dash should come ! It's when the engine is still running an those lights come is when you need to worry ! You need to check for spark an fuel pressure. If no spark probably an ignition module , crankshaft position sensor or distributer module , what ever ignition system it has. If there is spark spray some carburetor clean into the engine , if it try's to start you have a fuel delivery problem , fuel pump , relay ! No Start Diagnostic Basics EricTheCarGuy
May 09, 2015 | 1998 Toyota Corolla Sedan
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
Engene dies when is started
It can be issue with fuel pressure,its low or the problem relates to faulty spark plugs.
There are few troubleshooting steps to confirm the problem.I suggest you few help links,with complete troubleshooting and solution for these types of issues.
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm? http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1994 Lexus ES300: Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
Stalls And Dies At Stop Sign? http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
These help links will help you to troubleshoot and solve the issue.
Thanks.
Oct 21, 2012 | Cars & Trucks
"Stability Control Fail" light on.
first job is to check the part load and main beather hoses are ok the stability system light may be a false indicator if the engine has stalled best is to get fault codes out of the ecm with a code reader to help but air leaks on the engine inlet side can cause strange/seeming unrelated symptoms
Aug 22, 2017 | 1997 Jaguar XK8
Buick lesabra 2001 dies while driving, voltage light comes on.
hello, you may need to have engine tuned up, have choke checked out, usually all the lights,bells and whistles will come on after it dies.because you are having to start engine again, when first starting engine, see what all lights comes on, then when engine dies it should be the same lights coming on when first starting engine, thats pretty normal ,have all filters checked out like gas filter, air filter etc
Apr 08, 2010 | 2001 Buick LeSabre
Engine died.won't start.
Sounds like your crank sensor is faulty.These engines are known for crank sensor and ingition control module problems
Aug 15, 2009 | Pontiac Trans Sport Cars & Trucks
My engine in my '03 toyota matrix xr dies.
check the mass air flow sensor it is hooked with air cleaner
Feb 23, 2009 | 2003 Toyota Matrix
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
