Question about Hunter Fan 20527 Ceiling Fan
Harbor breeze fan beeps
Every so often the ceiling fan starts beeping every couple of minutes. It only lasts a half hour or so but it's driving me crazy. Make it stop
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Minka Aire Ceiling fan turns on by its self
Try changing the frequency in the receiver & transmitter.
Mar 19, 2013 | Minka Aire Ceiling Fan
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Beeping sound in Emerson CF1 ceiling fan
mcdevito75 here, Are you sure it:s the fan makeing a beep or a smke alarm that needs a battery??.
Jul 27, 2010 | Emerson CF1 Weathered Bronze Ceiling Fan
Lubrication
Getting lubrication into a ceiling fan is very difficult unless you take it apart, take it down and then turn it upside down.... Then spray WD-40 in around wwhere the fan blades hook up at. Then let it set for at least a couple of hours to let the lubricant work its way into the bearing. Turn it a bit and spraying more in every fifteen minutes or so will help to get it in there better.
Heatman101
Feb 27, 2010 | Hampton Bay 24002 Ceiling Fan
I have a Black & Decker digital steamer Model HS1300. The steamer works great but beeps 5 times every couple minutes when we use it...this usually indicates a low water level BUT the water level is...
I have the exact same problem - still no solution - this is the only posting I could find ... anywhere! If I figure out something, I will let you know. I love the steamer, but the beeping is also driving me nuts!
Feb 16, 2010 | Black & Decker Kitchen Appliances - Others
I have a Designer's Choice remote ceiling fan. I removed it from my mom's house and reinstalled in my house. However, the remote no longer controls the fan and lights. How do I reset the remote? My mom...
With mine, I turn off the full power and back on and it starts beeping and and press any button on the remote and it finds it and does a couple confirmation beeps.
Aug 31, 2009 | Hunter 52" Ceiling Fan With Light And...
F10 error on kenmore elite electric built in model 790.4907
Try unplugging the unit from the wall, wait 5 minutes and replug back in. I had same thing happen to me a few months ago. I had to leave my stove/oven unplugged for 24 hours to finally get it to reset itself. It is working fine now.
Aug 12, 2009 | Kitchen Ranges
Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Nov 29, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Hunter Fan 20527 Ceiling Fan Logo
322 people viewed this question
Top Hunter Fan Dryers Experts
Dan Webster
Dan Webster
Are you a Hunter Fan Dryer Expert? Answer questions, earn points and help others
