Question about Frigidaire Dehumidifiers
Frigidaire dehumidifier compressor does not run
Power is on, controls work,
MNTECH
  • 1543 Answers
SOURCE: dehumidifier
Most dehumidifiers these days have a built in defrost control, which turns the compressor off when the coils frost up while the fan continues to blow to help melt the frost off, so if it is frosting you may need a new defrost control, but first check the following: If your model has an air filter, clean it, as restriction of air flow will contribute to icing. Try to move the unit to a warmer location. Usually the best way to do this is to get it above the floor as far as possible, as the air temp is warmer closer to the ceiling than it is at the floor. Make sure there is plenty of room for air to circulate. (don't push it against a wall)
Posted on Sep 15, 2008
  • 117 Answers
SOURCE: My Soleus dehumidifier has stopped working after one year.
Sounds like cooling system, may be under warranty.
Usually cooling system warranty longer than other parts, at least a year and often 5 years.
Posted on Jan 07, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 05, 2010
heatman101
  • 43501 Answers
SOURCE: fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Posted on May 18, 2010
  • 36 Answers
SOURCE: frigidaire dehumidifier compressor does not seem
Either you have some sort of leak and there is no freon pressure or..Your compressor wont turn on because of a swith or control isn't telling it to..Does the fan still blow?
Posted on May 28, 2010
My Frigidaire dehumidifier compressor runs constantly and will not turn off with the switch. Have to unplug the unit.. Everything seems to be working to dehumidify. Is this a bad motherboard?
Does it run after you get to the optimal humidity level?
If so, it's a bad humidity sensor switch A cheap fix is to put it on a timer. Otherwise replace the switch.
Jun 21, 2017 | Frigidaire Dehumidifiers
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
Keeps running compressor
Hey randall, thank you for your post!
I see that you're stating the compressor continues to run on your Frigidaire dehumidifier. What you could be hearing is the fan running. The fan will run when the compressor cuts off so that air can pass over the sensor coils to check the humidity. Hopefully this is helpful. -Matt
Sep 12, 2014 | Frigidaire Dehumidifiers
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Why is it noisy and not pulling water from air?
If you can hear its fan running but it produces no condensate, then it's apparent that either the compressor is not running, or that the humidity setting needs to be lowered. If the compressor simply won't start, then it's time to replace that unit. Compressor or controls repair is far too costly. It's best to put that money into a new dehumidifier. Frigidaire units are highly rated and that's what I would recommend as a replacement.
May 03, 2014 | Haier Dehumidifiers
When turn off. makes a humming sound. compressor seems to be running.
Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
I have a Frigidaire 30 pint dehumidifier, the fan is running, but I do not hear the compressor. There was a lot of dog hair inside when I bought it second hand. Did I get screwed?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Sep 04, 2011 | Frigidaire FDL50R1 Dehumidifier
Frigidaire dehumidifier compressor does not seem to be working
May 28, 2010 | Frigidaire FDL50R1 Dehumidifier
heatman101
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
My dehumidifier will not turn on
heatman101
Jun 11, 2008 | Goldstar DH504EL Dehumidifier
Dehumidifiers Logo
29 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
