Question about Maytag Neptune MAH5500B Front Load Washer
Machine is real loud like a bearing is going out when ever its on the spin cycle.
You most likely have a bad shock. there are two one on each side recommend replacing both
Posted on Jun 18, 2009
  • 1028 Answers
SOURCE: Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Posted on Jul 20, 2008
bestdarngood
  • 3037 Answers
SOURCE: Spin Cycle is very loud on front load washing machine
yes, you can, if you need a place to buy a new bearing, let me know the make and model and I will get you a link to purchase one from
Posted on Sep 04, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: WMT01 washing machine makes a very loud noise on
Remove belt, and spin drum by hand, if it is noisy,or feels rough, then it is the main drum bearings that have failed.
Please rate my solution.
Thanks.
Posted on Aug 16, 2009
milten1
  • 1304 Answers
SOURCE: My neptune washer is making a loud noise when in
unfortunately yes,
your main seal on the oter tub is drying out, and will continue to get louder until either the motor control fries due to resistance or it just seizes up
it can be reapired but you will need an new outer tub 500.00 spinner assembly 200.00 i could talk you through the reapir,, it really it that easy, but
for 700.00 you could easily replace the machine for brand new
i tell you this at the risk of a bad rating beacuse i bear bad new,, but i wanted to be as honest as possible to allow you an informed decision before you proceeded
Posted on Oct 27, 2009
How to clean drum wont let me choose cycle ?
If it is really loud and noisy when on spin it will almost certainly be worn or rusty bearings. Workshop job to dismantle and replace the parts.
Jul 18, 2016 | Fisher and Paykel Fisher & Paykel Washer
There is grease coming from uner the washing machine and it makes a loud noise when it is spinning? Sometimes the washing machine will get hung up on the spin cycle?
Oil usually from the leaking transmission. a clutch not engaging might make a noise but u will get no real spin and clothes remain wet? if it was bad motor coupler if u have direct drive u would also have no spin or wash cycle. I suspect a bearing prob withing the tranny SORRYYYYYYYY :(
Oct 17, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Jul 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Squeaky basket and loud vibration when in spin cycle.
Bearings worn, belt loose and probably motor brushes.
May 17, 2012 | Kenmore HE3T Washer
Washer drains on cycles and clicks real loud and does not spin. When hand turning the drum, it is very stiff. When I turn the coupler, it spins and something under the tub spins but the tub does not...
it could be the bearings are worn, one way to check is to open the door hold the drum at the top and try to lift it up and down, if it is the bearings you will feel quite a lot of movement
Jul 21, 2011 | Washing Machines
When in spin cycle machine makes a very loud whining noise
Most common cause for your whining noise is because the seals have failed/worn and allowed water into the bearings..Rusty ball bearings are not smooth...Hence the noise.....Probably needs bearing/seal and probably shaft replacement....Big job..Get quotes....Good luck...Nomess
May 20, 2010 | Washing Machines
WASHER MAKES SQUEAKS AND SOUNDS REAL LOUD DURING
it could be a split pipe but its far more likley to be the drum bearings on the way out thats why its so loud and thats also were the water is coming from as well
not a cheep repain to get done,,,
sorry for the bad news
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
