Question about Dritz Clothing Care Jumbo Lint Shaver
HOW DO YOU OPEN THE LINT COMPARTMENT??????????
How to remove the lint house in a kenmore front load dryer
I would just get a long lint brush from a hardware store and a vac . Removing the housing is more trouble than its worth if you do not know what you are doing
Feb 16, 2013 | Dryers
How you open the bottom compartment to clean the lint?
depending on which model, but a rule of thumb is unscrew the bottom plate , and that lets you into the beater bar, belt, and end caps, make sure and clean all of the mentioned pieces for better cleaning preformance
Jul 11, 2011 | Eureka Vacuums
It is telling me to open the rear compartment and clear the paper jam. However, there is no jam. I have already tried to hold the help and ok buttons simultaneously with no change.
Turn off the printer.
Open the rear access door.
You need the clean the rubber rollers with lint free cloth. There could be dust particles stuck on the rollers. Cleaning it with lint free cloth ( clean upwards exactly like the rollers roll after picking up the paper )
Close the rear access door firmly.
The printer should work fine.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | HP Photosmart C4150 All-In-One InkJet...
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
My dryer has a build up of water and give an F03 error. What can do to fix it?
Aug 08, 2010 | Bosch WTE86300 Electric Dryer
How do you take the Lint Filter holder out of Dryer?
There should be a small trap door located on the top of your dryer. Open the trap door and pull out the filter cartridge. Carefully clean the screen and place back into the compartment.
Jan 25, 2010 | Maytag Dryers
Whirlpool dryer lint screen will not slide back into receptacle.
YOU PROBABLY WILL HAVE TO OPEN THIS DRYER UP BY REMOVING THE BACK COVER. ALSO WHERE YOUR LINT FILTER GOES IN AT THERE WILL BE 2 SCREWS UNDER THAT LID TAKE THEM OUT AND PRY THE TOP UP AT THE EDGES ON THE FRONT BETWEEN THE TOP AND FRONT PANELS. THEN REMOVING THE DOOR SWITCH WIRES AND THE 2 SCREWS THAT HOLD THE FRONT PANEL TO THE CABINET AND LIFTING THE FRONT PANEL UP AND OUT. NOTE THE DRUM WILL FALL A COUPLE OF INCHES. NOW YOU CAN UNDO THE DRUM BELT AND REMEMER HOW IT GOES BACK IN. THEN REMOVE THE DRUM. NOW LOOK TO THE RIGHT OF YOUR LINT CATCHER COMPARTEMENT. YOU WILL SEE 2 5/16 HEX HEAD SCREWS, REMOVE THEM. NOW GO TO THE REAR OF THE DRYER AND REMOVE THE SCREWS THAT HOLD THE LINT CATCHER COMPARTMENT TO THE BLOWER HOUSING. NOW GO BACK TO THE FRONT AND SLIGHTLY PULL THE BULKHEAD WHERE YOU PREVIOUSLY REMOVED THE 2 HEX HEADS(ABOUT AN INCH APART) TOWARD YOU WHILE PUSHING THE CATHER COMPARTMENT AWAY TO DISENGAGE IT, AND NOW YOU CAN SLIDE IT OUT AND CLEAN THE GROOVES THAT THE LINT CATCHER SLIDE INTO. REASSEMBLY IS IN REVERSE. iF THIS SCARES YOU TOO MUCH TO DO TRY RUNNING A WIRE CLOTHES HANGER WITH A SLIGHT HOOK IN IT DOWN EACH SIDE OF THE GROOVE TO POSSIBLY CLEAR AWAY THE OBSTRUCTION. SHOULD YOU CHOOSE TO DISASSEMBLE IT, TAKE THE TIME TO VACUUM OUT ALL THE LINT BUILT UP IN THE CABINET, ON THE MOTOR, THE BLOWER WHEEL, AND ANYWHERE ELSE YOU CAN GET A VACUUM HOSE TO FIT OR GO. GOOD LUCK AND I BELIEVE YOU CAN DO IT IF YOU FOLLOW THESE INSTRUCTIONS. P.S DON'T FORGET TO HOOK THE DOOR SWITCH WIRES BACK ON. THAT SEEMS TO BE MY DOWNFALL WHEN WORKING ON DRYERS, AND YES IT MEANS RE-OPEN AND HOOK UP, BUT I'M GETTING BETTER AT IT. :)))
Apr 11, 2009 | Dryers
How To Open Bottom of Dryer
Take the back cover off and there is a compartment that hook to the hose, with the right tools you can pull the compartment out and clean it to include other parts showing. hope I helped allittle.
Mar 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hello, getting an error of F:03 on my WTE86300US Bosch Condensation Dryer. Do you know what the issue is?
Aug 06, 2008 | Dryers
Dritz Clothing Care Jumbo Lint Shaver Logo
102 people viewed this question
Top Dritz Home Experts
Donni Steen
Tom Chichester
Are you a Dritz Home Expert? Answer questions, earn points and help others
