Question about Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Squeaking fan belt
When i sprayed purple cleaner in the front it started sqeuaking, now I am not sure which belt is making the noise
I have a kenmore washer dryer ( stacked ) heavy duty 2 speed motor . The top dryer is SQEEEEAKING so loud it is making me INSANE . I removed the front of the unit so I could see the drum and belt ... then...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 23, 2011 | Kenmore Dryers
Tip
Automobile headlight and lens cleaner
# 1 Old automobile bodymans trick: sand lens with # 1200 sand paper,
use any automobile body rubbing compound and then clean off with
a soft cotton rag or towel. good luck!
#2 squeeky fan belt, mix some cheap dish soap in a spray bottle
and spray on fan belt or belts if belt stops making noise, just
replace fan belt. good luck!
on Jun 25, 2011 | Chevrolet C3500 Cars & Trucks
Cold start fan belt squeak... slight misalignment
its possible that a pulley replacement is needed but i would first reccomend buying a lubricating spray from your local hardware store and applying it to your squeeling belt if the noise stops then you may just need to tighten or replace the belt. in addition an overtightend belt can cause undesired stress on the pulleys.
May 24, 2010 | 2000 Kia Sephia
Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Oct 25, 2009 | Hoover Vacuums
Have a horrible squeling noise when A/C is turned on i think i am looking ast the alternator where the belt goes on and the wheel seems to be sticking
Sounds like you need a new belt,but check if tha A/C is turning when you switch it on ,if not then you will need to repair/replace the A/C.
Aug 09, 2009 | 2000 Dodge Caravan
Squeaking near belt area
have you tryed replacing the belt when and if you replace the belt check the pulleys that are driven by that belt for nosie do not try spraying any thing on the belt just make things worse kdc744
Feb 06, 2009 | 2007 Chevrolet Uplander
Squealing noise under the hood
No, The fan clutch will not make a Noise it will just not catch the Fan to Cool. It is the Belt. Make sure that it is Tight. You may have a Bad Belt Tensioner if it is not.
Jan 23, 2009 | 2004 Chevrolet TrailBlazer
Fan belt engine trouble
faulty water pump grinds and squeaks
stuck thermostat
cooling fan /slipping clutch =spinning to slow or faulty relay
oily fluid .spray
..oil and coolants mix
could have blown a head gasket by now
Apr 11, 2017 | 2006 Hummer H3
Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
15 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
