Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox epp5251 g105, it is foggy, the only color you can see is green. looks very bad.
  • Philips Master
  • 8,617 Answers
The a problem which is caused by the picture tubes ( CRT) coolant needing replacement. You can get the kit which contains coolant for the tubes plus a cd with detailed instructions with pics on how to do the procedure.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Posted on Jun 18, 2009
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
My 51 inch Magnavox rear projection has red and green overlapping
the coolant is bad inside the blue and green pix tubes-to verrify this you can remove the front edge of the screen(it pulls off-one edge at a time-take out screws to remove screen-after screen is off look down at blue/green tubes pix is bad or not there
Sep 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Blurry screen
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to...look white, look dull, look red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Distorted Picture and High Pitch Squeal
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 31, 2009 | Philips Magnavox 51MP392H Rear Projection...
My 60inc phillips magnovox has poor color, what do i have to do?
we just bought a 55 inch phillips magnavox and told it was working fine when we got it home and turned it on it was a red screen and was really foggy. we looked up some tv repair places and ONLY 1 told us it was the picture tube and to look down them with a flashlight for bacteria! sure enough the green and blue had it. so we found one place that would sell us the coolant fluid that you have to change the others could get it in or wanted us to bring the tv to them. we did it our selves the stuff was $17.00 a bottle or if we took it in it would be about $375.00. we have a great picture now and it wasn't as hard as all the other repair places said.
Dec 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hello thanks the model # is FP5251 G105
Thats the PTV711 chassis phillips magnavox. I would suspect the vertical output IC needs to be resolderd. Its located on a aluminum heatsink and should have vertical stamped on the board near where the IC is located. Often when the vertical drops out it causes the CRTs not to light as a safety feature to protect the tubes. let me know if you need more assistance.
Jun 01, 2008 | Televison & Video
Philips - Magnavox Model # 9P6034 C103 Picture problems? Please Help
1 5 oz bottle should be enough for each tube. The small picture is caused by bad opto-couplers on the large signal board. Let me know if you need more info on the couplers and where to get them
May 15, 2008 | Televison & Video
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
