Code B2580 what does that mean 2007 grand prix
  • 114 Answers
SOURCE: changing serpentine belt 3.8 2007 pontiac grand
  • Make sure your new belt exactly matches the old belt demensions
  • Take a breaker bar or big rachet & release the tension on the automatic tensioner; very slowly
  • Loop the old belt around the pulleys & fan
  • Install new
Posted on Oct 17, 2009
  • 417 Answers
SOURCE: for pontiac grand prix what does trouble code
Appears to be the code for the camshaft position sensor, or cam sensor circuit. Around $35-45.00 for the part at an auto parts store. Have the part replaced. And take it from there. Might be a good thing to replace the spark plugs and wires too.
Posted on Apr 02, 2010
canwoodjc
  • 3301 Answers
SOURCE: color codes for a 2007
http://www.installdr.com/Harnesses/GM-Wiring.asp thats what you need follow the last one
Posted on Jul 25, 2011
emissionwiz
  • 75822 Answers
SOURCE: what is code PO496 and PO455 for a 2007 Pontiac Grand Prix mean
P0496 is not alisted code.
P0455 - Evaporative Emission Control System Leak Detected Gross Leak (fuel vapors)
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors Possible causes - Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
Posted on Jan 24, 2012
  • 306 Answers
SOURCE: I have a 2007 grand prix. The lowbeams work but
This would be the third time I've run across this one. I believe one of your low beam filaments burnt out but you didn't notice it much since you still had one working. When the last one went out this gave the appearance that both suddenly died. Unplug each headlight bulb and check with an ohmmeter for "opens" (high resistance). I'd bet you need to replace both the bulbs.
Posted on Feb 27, 2012
Will Vaseline lock the engine if you prime the fuel pump with it on a 2007 grand prix
There is no need to prime the pump with anything on a 2007 Grand Prix. The pump is submerged in the fuel tank and will push fuel to the engine without priming.
Dec 22, 2016 | 2007 Pontiac Grand Prix
Why won't my 2007 grand prix go forward??
Depending on mileage and care...100K+ could mean low on tranny fluid (1) dirty clogged tranny fluid & filter (2) wheel bearing worn/locked? If you think it is dirty/low on tranny fluid, try adding a bottle or 2 of Lucas Oil Transmission Stabilizer...works great without draining anything...try this first...any other symptoms?
Jun 09, 2015 | 2007 Pontiac Grand Prix
2007 Pontiac Grand Prix heater dosent work
blend door actuator stuck on cold setting .... make sure ur not low on coolant to cause that will always mean no heat
Jan 04, 2014 | 2007 Pontiac Grand Prix
Ok so I just bought a 2007 pontiac Grand Prix and this yellow check engine type light is on that has an exclamation point over it. What does this mean?
This light comes on to alert you to the fact that a fault has occurred in the engine control electronics. You must have the computer scanned to read the code that was stored in the memory when the light came on.
Apr 20, 2012 | 2007 Pontiac Grand Prix GXP Sedan
What is code PO496 and PO455 for a 2007 Pontiac Grand Prix mean
- Fuel tank leaking
Jan 24, 2012 | 2007 Pontiac Grand Prix GXP Sedan
Our 2005 Pontiac Grand Prix is hard shifting. The diag codes that came up are trans codes P1811c and P1819c. Does anyone know what these codes mean? I'm having an impossible time finding them. Thanks in...
The codes mean that the Electronic Pressure Control Solenoid is going bad. The computer detects that the shifts are taking longer than 0.65 seconds. Then the computer commands maximum line pressure to avoid burning out the clutches, hence the hard shifting. My 2002 Grand Prix had the same problem, and I had great luck just installing a shift kit to speed up the shifting and haven't had any further issues.
Nov 27, 2010 | 2005 Pontiac Grand Prix
1999 grand prix gt 3.8v 6 error codes 300 and 302
The PO300 code is random/multiple cylinder misfire detected. Sinsc you have the code PO302, that means that cylinder 2 is the one misfiring, usually a bad coil pack, or spark plug.
May 12, 2010 | 1999 Pontiac Grand Prix
Code P0442 on a 2000 grand prix
That means that there is a fuel evaporation leak detected in your fuel tank. Generally this means that your fuel cap is loose- go tighten it and see if the code goes away after driving your vehicle for awhile. The problem can also be holes in the evaporation hoses...but not likely.
Feb 22, 2010 | 2000 Pontiac Grand Prix
Aux input location
Though I'm sure there is an AUX button on the radio, there isn't actually an auxillary port on a 2007 Grand Prix stock radio.I'm sorry to say, but you would have to get an aftermarket radio.
Mar 11, 2009 | 2007 Pontiac Grand Prix GXP Sedan
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
