Question about HP OfficeJet 7410 All-In-One InkJet Printer
The printer can't get past the warm up phase
I've tried all the unplug and wait routines as well as hold certain keys down at once routines and nothing works. Tried online help desk and their solutions for holding different keys down don't work either. I guess its simply 500.00 down the drain.
    Guru:
  • 224 Answers
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible. If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product . Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
  2. Make a color copy by pressing the Start Copy Color button on the control panel.
  3. If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
  4. Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Step one: Perform a partial reset
  1. Unplug the power cord from the product.
  2. Press and hold # and 3 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel. If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
  2. Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.Now if this still does not work call in to hp at 1800-474-6836 if your printer is out of warranty directly dont go for any troubleshooting just ask the agent who answers you call to give you the upgrade options(printers with a 50% discount with a years hardware replacement warranty as well as software help warranty ,which can be extended fro about 3 years)its basically a factory refurbished printer which means that if wallmart purchases a 100 printers and realises they need 99 then they send one back to hp thats what is called refurbished but no one has used it,if you get an option of a officejet J6480 that is the best printer I have it my friends have it my relatives also have it in autralia and canada.......wonderful printer easy to use and is usb as well as wireless capable
Posted on Jun 19, 2009
I have an HP C6380 it comes up with the error message "Ink cartridge access door is open" It isn't but I can't override the message. Any help?
Please follow the next steps:
I also tried this:
1-power off unplug power cable wait for a minute
2- Press and hold both "#" and "6" keys Plug-in power chord
3- Be patient Wait for the screen to blank out.
4- Release #6 keys press power on button
Mar 19, 2013 | HP Photosmart C6380 All-In-One InkJet...
My hp laserjet 3330mfp reports a scanner bulb is warming up and it never goes off. I have tried to unplug then plug back in. The printer works fine.
Here is how to cold reset the machine. also I added some addtiona options below as well.
1 Unplug (or turn off) the product from the power source.
2 Press and hold down the * and menu/enter keys.
3 Continue to hold down the keys while you plug back in (or turn on) the product, through the entire power on sequence.
4 When the control panel display reads Permanent Storage Init. release the keys.
5 Allow the product to return to Ready before using the product.
If that doesn't work it can be a power related issue,
- Make sure it's NOT plugged in to a surge protector.-
- Try a different outlet on the wall.
if theses steps fail you will most likely have to replace the scanner assembly
Another Option you can try as well :
Also I found this on a HP forum NOT SURE IF IT ACTUALLY WILL WORK:
" Scanner Bulb Walkout - Unplug the power from the unit,plug the power back in wait until the unit reads "Scanner Bulb Warming Up" Unplug the unit. Repeat this step 5 times.
This should move the scanner assembly back to its home position.
link to this post : http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=989123
Oct 20, 2010 | HP LaserJet 3330 All-In-One Printer
0xc18a0406
Hi there
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 26, 2010 | HP Photosmart 3210 Printer
I get the following error message from C5180 printer: 0xc18a0001. What should I do?
Hi there
0xc18a0001.
5. Wait 60 seconds.
Or try 2
Or try 3
Mar 01, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
5. Wait 60 seconds.
Or try 2
Or try 3
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Am getting error message of 'alignment failed'. black cartridge will not print
You can run into a problem aligning print heads on almost any HP All-in-One. Fortunately, the problem is usually with the paper or cartridges, not the printer itself.
The quick and dirty fix is to skip the alignment. With the HP printer, you can do that by holding the Enter button down and pressing Setup.
When you're ready to tackle the alignment issue, check the paper first. If there's anything written or printed on the page, if it's any color but white, or if its brightness level—which should be on the package—isn't at least 85, you can't use it for alignment.
If the problem isn't the paper, it's almost certainly the cartridges, which could be low on ink (if you replaced only one cartridge), defective, suffering from clogged nozzles, or past their shelf life.cartridges include a use-by date on the box. The dates tend to be conservative, but if the deadline is long since past, the cartridge could be all but useless.
Run the cartridge-cleaning routine, and then try aligning the cartridges again. If the problem was with clogged nozzles, the cleaning routine might fix it. If it doesn't, the next step is to try cleaning the cartridges and the contacts in the printer. Once you've cleaned the cartridges, try the alignment routine again. If it still fails, and you feel rich enough, you might want to try a new set of cartridges. Or, you might want to bypass the alignment again and use up the ink in the current cartridges first.
Jan 12, 2010 | HP Officejet 7210 All-In-One InkJet...
How do I fix error SC552 on Ricoh 2238C?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared
Oct 04, 2008 | Ricoh Office Equipment & Supplies
HP Photosmart C6100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You can try to reset the unit to its factory defaults by performing the following steps .
unplug the power cord from the back of the unit without turning off the printer.
press n hold # key and 6 key together n do not release the keys ,while holding them down plug in the power cord back into the unit.
wait for a few seconds as it would make certain noises and turn off , when the unit turns off release the keys .
after a few seconds turn on the printer , wait as it wud go into initialisation mode > might ask to press 1 for language (please follow instructions ) it would give 2 or 3 allignment sheets.
5
after its done try to copy.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} note - after the RESET fax seeting are to be done again as it goes to factory default settings .
Thanks
May 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
WON'T SEND FAX FROM FEEDER.
u can try the following steps >
unplug the power cord from the back of the unit [without turning off the unit ] > press and hold ok and cancel key together > while holding these keys down plug in the power cord back into the unit . do not release the keys > wait for a few seconds it will make certain noises an wud turn off automatically .
turn on the printer again it will go into allignment phase > let it finish.
after its done > try to make a copy from the feeder .
Note - In case [ok and cancel key ] combination doesnot work < u can try # and 6 key combo as well with the same procedure.
THANKS
Mac
Mar 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7310 print cartridge
As u have already tried a few steps and repalced teh carridges as well, u can try the following steps as well .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Thanks
Dec 06, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
338 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
