Question about MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color
I have an AA Mini Maglite and it quit working. I replaced the two batteries and lamp and still does not work. Any suggestions?
I have several of these flashlights and experienced the same problem. Here's my solution: take off the light end and you will see a black base where the bulb is inserted into. The black base rotates. If all else is functional (batteries, bulbs, etc.), when you rotate this black base, the light should come on. Moving the base back and forth several times seems to help also (it seems there must be some kind of contact problem). All that's left is replacing the light end.
Posted on Jul 13, 2009
  • 45 Answers
take the bottom piece off, remove the last battery and put a coating of petroleum jelly on the threads of the tube. Then take the bottom piece and run it all the way in and back off and back in 2 or 3 times. Then put a little more petroleum jelly on the threads and put the battery back in and the bottom piece. This should do it.
Posted on Oct 19, 2012
  • tonypeot
    tonypeot Oct 24, 2012
    Tried batteries and new bulb.....lubed the threads and it worked great! Good tip!
  • David Black
    David Black Dec 07, 2016
    GREAT!
    Champion:
  • 225 Answers
Try unscrewing the cap that holds the batterys in place , there should be a spring on that cap,sometimes if you streatch the spring a little bit seems to help.
Posted on Jun 18, 2009
How do I replace batteries on a Mini Maglite AA
unscrew the bottom end, dump out batteries, replace, put cap back on tightly
Jun 23, 2017 | MagLite Camping, Backpacking & Hiking
Tip
How to replace the lamp in a Mini Maglite
The Mini Maglite is a durable, compact flashlight. If your Mini Maglite stopped working, check or replace its two AA batteries first, and if that doesn't fix it, you'll probably need to replace the lamp. You can order replacement lamps in packs of two online, or you may be able to find them locally in a hardware store.
To replace the lamp in a Mini Maglite:
1. Unscrew the bottom of the flashlight. (Hold the flashlight with the head facing down so that the batteries don't fall out.)
2. Remove the batteries.
3. Unscrew the flashlight head from the barrel.
4. The lamp is mounted into the flashlight on two prongs; gently pull up on the lamp to remove it.
5. Install the new lamp by lining the prongs up with the two holes and slowly inserting it fully.
6. Screw the flashlight head back on.
7. Reinsert the batteries.
8. Screw the base back on.
When you've finished, turn the flashlight on (by turning the lens cover or the head counter-clockwise) to verify that the new lamp works. If the light doesn't come on, take the flashlight apart again and check to make sure the lamp is installed correctly and fully. Since the lamps come in packs of two, if you can't get the first lamp to work, try the second lamp in the pack. If that lamp doesn't work either, check your batteries and make sure the lens cover and head are both screwed on all the way.
on Jan 12, 2011 | Kitchen Appliances - Others
I cannot get the cap off to replace the batteries of my mini maglite 2 cell AA
Probably a leaking battery has coroded the cap. You can send it direct to MagLite for warranty. Go to: http://www.maglite.com/repaircenters.asp
to find the nearest warranty/repair center.
Gary
Nov 14, 2010 | MagLite Mag-Lite& Flashlight
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
Jun 30, 2010 | MagLite Mag-Lite& Flashlight
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Corroded batteries stuck in a mini AA maglite
yes the bulb assy can be removed as it's basically the switch you need like a special tool for removing it. but first which brand of battery is in it. both energizer and Duracell have warranty about replacing item that the battery has damaged. try that route is my suggestion before trying to remove batteries and possibly breaking the switch. you can get one sent to you by calling up customer service as i replaced one before mini mag lite also.
Oct 04, 2008 | MagLite Camping, Backpacking & Hiking
MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color Logo
4,959 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
 steve
steve
Alec Oren Orris
Level 1 Expert
Jovan Sakovic
Jovan Sakovic
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
