Question about Home
My 1995 150 johnson fast strike only shows 5100 rpm at 62 mph should it show more at full throttle
Should this motor not turn more rpms at full throttle
  • 150 Answers
SOURCE: idle at 1500 to 2000 rpm
Most likely the throttle body gasket (between the throttle body and the intake manifold) is leaking.
Posted on Feb 12, 2009
SOURCE: Johnson Outboard Motor 175HP
Not knowing what year it is...Light and alarm? Reason: overheat low oil etc. check water flow..water pump. The motor is most likily going into S.L.O.W mode. its a fail safe system. Last possibile reason ..CDI box and or stator.. pull plugs check compression...should be 120-150 lbs.
Posted on Feb 21, 2009
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 4 Answers
SOURCE: 2000 oldsmobile alero fast idle
Just fixed mine today, check the vaccum tee off the manifold to the check valve, mine was cracked, repaird with electrical tape for now.
Posted on Aug 22, 2009
SOURCE: 98 Chevrolet Silverado runs rough at half throttle and past.
try removing the EGR valve and clean inside of it and manifold
Posted on Feb 17, 2011
Wanting to lower idle on my gc160 honda engine rpms are to fast for my 1000 rpm hypro pump
Locate throttle setting on carb usually it will be a screw through a spring,start engine then turn counter clockwise slowly until reaching desired RPM.
Apr 14, 2018 | Honda Cars & Trucks
I have a John Deer DP 6000 portable generator. The rpm is producing 62 cycles at no load 1/2 voltage rotor has no brushes replaced both capacitors have flashed them both with 12vdc while running
62 Cycles is just going to make a clock run a little fast ,but its ok.
There might be a load sensor on the gen set. That will only allow the to run at full throttle with a load applied on it .
Just a guess.
Feb 14, 2017 | Electrical Supplies
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
High rpm sounds at higher speeds
Sounds like idle control not set right check for damage to throttle cable to but seems to be idle control wiether it be a sensor if fuel injected which would have to be reset at mechanics or just sensor if has carb check idle screw
Feb 21, 2013 | 2005 Toyota Corolla
2003 gsx-r 600 rpm does not work
they do not work together, your tacometer is eletric meter that reads the rpms the engine is turning. the speedometer is mechanical and shows how fast your traveling down the road.
Nov 02, 2012 | Suzuki Motorcycles
Idle rpm too low
are you reading your rpms right....5-6000 rpms should equal 70- 85 mph....that is certainly not idle speed....invest 20bucks in a Haynes manual----it is good reading
Mar 01, 2010 | 2007 Chevrolet TrailBlazer SS
8hp johnson, 1999,plugs good, wires good,have put in new gasoline 50.1 mix, runs great at higher rpms. When cold start, it will idle at slow rpm. Once warmed up or a hot day, it will not idle when the...
have u tried to adjust you timming linkage? its on the side of the motor where the shifter linkage is try to turn the bolt in or out while running you may get it to idle better if the power pack was bad the engine would cut out at all speeds
Apr 16, 2009 | Light Outboard Motor Boat Bass Fishing...
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
