Question about Whynter ARC-12SDH Portable Air Conditioner
Service whynter com
Air conditioning green button will not come on dehumidifi button works purple light ok blue light works also but not green ac light skips over ac function
2 Suggested Answers
  • 4736 Answers
SOURCE: Brand new Whynter ARC 12
Check the positioning of the water bucket It may be slightly out of place and is not triggering the switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit for 12 - 15 minutes. Then plug it back in and turn the Master Switch ON/OFF Switch to ON. Set the controls and it may have reset itself.
If none of the above soled the problem contact the manufacture's Customer Support or Tech Service Dept.
Hope this helped you to solve the problem. Please let me know. Thanks.
Posted on May 05, 2011
Control panel lights on whynter 12000 btu portable air conditioner .can't read some numbers
This is due to the detrioting condition of the display, sometimes an even lite press with fingers on the display may help. This happens due to loss of contacts inside due to poor quality of display or aging.
Oct 13, 2015 | Whynter ARC-12S ECO-FRIENDLY 12000 BTU...
Need wire color diagram
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
Brown = AC 3 pahse - phase A
Orange = AC 3 pahse - phase B
Yellow = AC 3 Phase - phase C
shileds: think of current loops
2 cond
clear or red = +
black = -(neg)
3 cond
red = power (24vdc typically for transducers)
clear = + (signal output)
black = - (signal common)
Hope this helps, oh, and any panel I have design and wired this way is easily understaood by 99% of all service and electrical people I have worked with.
Apr 15, 2015 | Cars & Trucks
My everstar portable ac is not running properly. In cool mode only the fan is running if I shut off the unit and restart the compressor comes on and then shuts right off the green light blinks briefly and...
Ed, there are several things that can cause this problem, but all are solvable.
1. The current temperature setting is not low enough.
2. The air intake filter needs to be removed and cleaned.
3. The water collection tank is full and needs to be drained.
4. Obstruction in the exhaust hose(s).
Be sure to turn the unit OFF & unplug it, before attempting any service work on the unit.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 12, 2011 | Whynter Portable Air Conditioner
Brand new Whynter ARC 12 SD, just plugged in and red warning light about power button is blinking. Booklet says the light will blink when water reservoir needs to be emptied. But, it's brand new, no...
May 05, 2011 | Whynter Portable Air Conditioner
I need to know what color the ignition wire is so i can install a kill switch on my 06 F250 Powerstroke
hi, hope this will help.....if it does, could you leave a positive feedback for me please...many thanx..........
PART COLOR LOCATION
12 VOLT CONSTANT BLUE/RED (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 WHITE/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BROWN/YELLOW (+) IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 PURPLE/GREEN (+) IGN SWITCH HARNESS
KEYSENSE BLUE/GRAY (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GRAY (-) AT HEADLIGHT SWITCH
PARKING LIGHTS ( + ) PURPLE/WHITE (+) SMART JUNCTION BOX IN PASSENGER KICK PANEL
POWER LOCK BLUE/LIGHT GREEN (-) TYPE (B) IN DRIVERS KICK PANEL
POWER UNLOCK YELLOW/PURPLE (-) TYPE (B) IN DRIVERS KICK PANEL
DOOR TRIGGER VIOLET(+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
DOMELIGHT SUPERVISION GREEN/BLUE (-) HEADLIGHT SWITCH
HORN YELLOW/RED (-) AT STEERING COLUMN HARNESS
TACH BLUE(AC) AT HARNESS NEXT TO BRAKE PEDAL
WAIT TO START LIGHT N/A N/A
BRAKE PURPLE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
Aug 05, 2009 | Ford Super Duty Cars & Trucks
Danby DPAC13009: Light yellow instead of orange for dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 28, 2009 | Danby DPAC12031 Air Conditioner
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
I need a wiring diagram for a 1999 Jeep Grand Cherokee
Here is the stereo wires which may help you figure out which are not the ac wires etc. hope this helps with some of the problem.
Constant 12V+ Red/White  Switched 12V+ White/Red  Ground Black  Illumination n/a  Dimmer Orange  Antenna Right Front  Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red  Left Front (-) Light Green/Green  Right Front (+) Light Blue/Red  Right Front (-) Light Blue/Black  Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White  Left Rear (-) White/Dark Green  Right Rear (+) White/Purple  Right Rear (-) Tan/Dark Green
Nov 14, 2008 | 1999 Jeep Grand Cherokee
Whynter ARC-12SDH Portable Air Conditioner Logo
19 people viewed this question
Top Whynter Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Whynter Heating and Cooling Expert? Answer questions, earn points and help others
