Question about Health & Beauty
HuBDIC blood pressure unit shows Er 4 on screen. What does this mean?
  • 2712 Answers
SOURCE: blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
Posted on Aug 27, 2008
  • 4 Answers
SOURCE: Only blood pressure result I get is 'EE'
That either means you are moving, or you are inflating the cuff to soon after turning it on. Either of these is what mine means when I use it.
Posted on Jan 19, 2009
  • 6 Answers
SOURCE: I've lost the directions for the Mabis Wrist Monitor 04-235-001
e-mail customercare@mabis.net and they can give you the directions to your unit. Include the model number found on your wrist unit.
Posted on May 12, 2009
DrRonJupiter
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Posted on Oct 13, 2009
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
What does Er 4 mean on my cvs blood pressure machine
YOU did NOT SPECIFY your MODEL NUMBER but tonight ~ Christmas Eve ~ YOU got LUCKY! I found this and it may help you... but
THIS INFORMATION MAY NOT BE FOR YOUR DEVICE!
"LCD shows "Er 4"
Pneumatic system leak
or cuff is too loose during inflation
And this:
LCD shows "Er 0"
Pressure system is instable before measurement
Be still and measure again
LCD shows "Er 1"
Systolic pressure detect fail
LCD shows Er2 Diastolic pressure detect fail
LCD shows "Er 3"
Pneumatic system is
blocked or cuff is too
tight during inflation
Place the cuff correctly
and try again
LCD shows "Er 4"
or cuff is too loose du-
ring inflation
LCD shows "Er 5"
Inflation
above
300mmHg
Measure again after 5
minutes. If the moni-
tor is still abnormal,
please contact the
local distributor / ma-
nufacturer.
LCD shows "Er 6"
Over 3 minutes while
pressure above 15
mmHg
LCD shows "Er7"
EEPROM accessing er-
ror
LCD twinkling
Device
parameter
check error
LCD shows "Er 9"
MCU self-verity error
LCD shows "Er A"
Span error
LCD shows "Er b"
EEPROM Backup-error
http://webcache.googleusercontent.com/search?q=cache:V0KPe0jswmgJ:www.hmm.info/uploads/tx_sbdownloader/smartLAB_profi_user_manual_ENGLISCH_R4.pdf+&cd=2&hl=en&ct=clnk&gl=us&client=firefox-b-1
Dec 21, 2017 | Health & Beauty
My monitor pressure life source UA 767 show in display error cuf , what mean thats error
The Err CUF probably means that the blood pressure cuff isn't properly arranged on the arm. Check that the cuff is around the upper arm 1-2 cm above the elbow. The hose should be near the center of the elbow. Make sure that a rolled up shirt sleeve is not too tight. Next check that the indicator arrow is in the correct range when the cuff is firmly fastened.
Make sure that you are using the correct cuff for the user. There are different blood pressure cuffs (medium, large, wide-range) available for some blood pressure monitors. If the arrow doesn't line up in the indexed range, use a different blood pressure cuff for the unit.
I hope this helps. I used the information about the A&D Medical UA-767 for some of the trouble-shooting details. See https://medical.andonline.com/product/premium-blood-pressure-monitor/ua-767f and click on the Downloads tab to see the manual for this model. (I suspect the Life Source and A&D Medical products are extremely similar.)
Nov 21, 2017 | Health & Beauty
What does the heart on the monitor means?
The blinking heart symbol indicates that the unit is slowly decreasing the pressure in the wrist cuff. This is when the unit is finding your Diastolic blood pressure. This is a normal symbol on most automatic blood pressure monitors. When a nurse or doctor uses a manual blood pressure cuff and listens to the blood flow, they will record the systolic pressure when they first hear the heart beat. Then they record the diastolic measurement when they can no longer hear the heart beat.
The manual for the KS-7902 is available here: http://pharmasupply.com/wordpress/pdf/wristman .
I hope this helps.
Aug 08, 2014 | Advocate Wrist Blood Pressure Monitor...
Error 03 is displayed
Error 3 means that the unit cannot power on and control the air pump -the unit itself is faulty. The screen is totally blank that means that the control processor in the main unit had malfunctioned.
You cannot fix the defective unit. Time to replace a new unit.
Jul 26, 2011 | Lumiscope 1092 Wrist Blood Pressure...
What exactly does the MAP/cuff mean or measure?
Basically, the ProCare Series Monitor, is used in a hospital setting, on patients being transported from surgery, tests, ER, etc. back to their rooms. It's monitors their heart rate, blood pressure, breathing & pulse rate, as well as acting as a portable EKG machine. It alerts the transporter of any significant changes in the patient's condition, that would require immediate action, to save the patient's life. It records & stores all that data, for later review, if necessary.
Hope this helped you.
Jun 23, 2011 | General Electric Dinamap ProCare Series...
I get error codes on the unit. Can you tell me what the error codes mean?
I AM GETTING ERROR 3 ON MY LIFESOURCE BLOOD PRESSURE MOINTOR 7 WHILEPUSHING ON START BUTTON,IT DOES NOT GO AHEAD MORE THEN FIGURE 2 & COMES BACK TO 1 & THEN SHOWS ERROR 3,CAN ANYONE,SUGGEST OR GIVE SOLUTION/REMEDY ON MY MAIL ID:hemant_pandya12@yahoo.com I HAD LOST OPERATING MANNUAL & WARRANTY CARD,ALTHOUGH THIS MONITORING INSTRUMENT'S HAVING LIFE TIME WARRANTY,INCLUDING CUFF. THANKING YOU.
H.M.PANDYA.
Mar 03, 2011 | Lifesource Digital Blood Pressure Monitor...
Hello.I have chicco sensor diagnostics thermometer model 69796. when I want to swich it on it says "Er 0" and in the upper left corner letter "F" blinks. what does it mean and how can I...
Hello
Try this to solve your problem:
  1. Power off the unit
  2. Remove batterys
  3. Wait five minutes
  4. Put batterys back on
  5. Power on unit
Please feel free to aska again if this doesn't solve your problem.
Dec 07, 2010 | Health & Beauty
It shows error 5,7, and 9 but I cannot find what these mean. Where do I obtain?
Contact OMRON - CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available
Monday through Friday - 8:30am to 4:30pm CT
Apr 20, 2010 | Omron Blood Pressure Monitor Hem 775...
I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
Feb 09, 2010 | Health & Beauty
The heart symbol means your pulse rate and the page is the memory page
Mar 28, 2009 | Mabis Blood Pressure Monitor Smartread...
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
