Tascam CC-222mkIII CD Player / Recorder
Problem for Tascam CC-222mkIII CD Player / Recorder
Tascam CC-222 not producing quality CD's Help
By kports on Jun 18, 2009
Our church uses Tascam CC-222, I believe 1997 model to record the services, it was noted recently that we are not getting services recorded on the CD's , going backward it appears this started about the end of April (now mid June) the noise coming off the recorded CD is static and sometimes you can faintly here the organ or piano. Could I have a bad bunch of CD's, could I clean the CD burner or is it broken and need of repair/replacement?
Any help would be appreciated
Solution #1
posted on Jul 17, 2009
Not Rated)
palaboy
Rank: Wiz  Home Audio  Expert
Rating: 83%, 1250 votes
hi,
check the setting of FRONT MIC/EXT MIC knob or REAR MIC/LINE knob might be too high,
lower it a little
check also input signal level may be too high, try lowering it
hope this helps, thanks for using Fixya!
Comments:
Jul 17, 2009
- here is additional info
Was this helpful?
Yes
No
Solution #2
posted on Jun 18, 2009
Not Rated)
MB Audio
Rank: Master
Rating: 85%, 13 votes
You need to verify that the signal going IN to the recorder is ok. There are a number of ways you can do this, the simplest and cheapest is to get another recording device you know works, that takes the same connectors, and test using that. Something like a cassette deck, or whatever a church member may have at home. If that works, you've determined that its the Tascam, if not, then you need to trace back to see where the signal failure is occurring.
Was this helpful?
Yes
No
Popular Solutions for Tascam CC-222mkIII CD Player /
Questions and Unsolved Problems for Tascam CC-222mkIII CD Player /
Do you recommend Tascam CC-222mkIII CD Player / Recorder?
Answer
Answer
tascam cc-222mkII cd door will not open. screen stuck on "Open OPC"
Answer
dad bloked tagged and facebook how can i unblock them so i can talk to my friends?
Answer
An old tape appears to have become jammed in the tape player. I need to know how to open the... (More)
Answer
I have a Bose Wave Machine that I would like to use (as speakers) for a PA system. I have a... (More)
Answer
How to record single track instead of multiple tracks on cd
Describe your CD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD Player Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
