Question about HP Office Equipment & Supplies
Disable checking printer function on startup
Go to print on hp 7610, and printer goes into "checking printer" mode. this happens EVERY time i print. wastes time and ink. a opain in teh keester. how to disable?
SOURCE: Hp Photosmart C3180-start-up
Okay, just chatted online with an HP tech, and she helped me solve the problem!
She said: the printer prints an alignment page everytime you turn on due to incomplete initialization process.
Turn off the printer and Turn on.
Please unplug the usbcable.
  1. Lift the scanner lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass.
  3. Place the alignment page face down
  4. Close the scanner lid of the printer.
  5. Press the Scan button.
  6. The On/Resume light will blink during the alignment process.
  7. After the On/Resume light stops blinking, alignment is complete.
  8. Turn off printer and Turn on.
It shouldn't print the alignment page any more! :)
Hope this helps!
Posted on Jan 01, 2008
  • 103 Answers
SOURCE: auto test page on the HP F 380
I don't know this personally, but you should be able to hit the power button and turn it off right after you load the cartridges. then power back on. That might do the trick.
Posted on Feb 03, 2008
  • 11 Answers
SOURCE: mp780 waste ink full
CANON MP 780 WASTE INK COUNTER RESET
Enter Service Mode : Menu – Scan – Copy – Scan
Select #7 PRINTER in the service mode, and
input “0” at # 5 INK ABS CAPA.
Posted on Mar 11, 2008
yooperbud
  • 8637 Answers
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
cene765
  • 787 Answers
SOURCE: My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Posted on Nov 16, 2009
All photos are printed with a blue tint behind them.
#Perform print head nozzle cleaning from printer properties..
# Do align print heads.. check.. repeat 2-3 times till good result comes.
Aug 02, 2015 | HP CR769A Officejet 7610 Wide Format All...
Laserjet 1536dnf mfp not waking out of sleep mode
Disable sleep mode or update firmware. Cause this is a firmware bug.
Nov 13, 2013 | HP Laserjet M2727nf Multifunction Printer
HP LASERJET P1606DN goes to offline
Happened on our print server this morning for the first time. We have 4 of 1606dn in our organization. Reset the print spooler and that brought it out of offline mode
Jan 09, 2012 | HEWLETT-PACKARD LASERJET PRO P1606DN...
I have an HP Pavillion ZE2000 laptop and it will nto boot up, push button to turn it on. goes to windows page then goes black and nothing happens will nto boot all the way up to windows page with icons. is...
press f8 at startup to get to the windows startup menu, choose "last known good configuration" If that fails, you can choose "disable automatic restart" and the BSOD, Blue screen will appear and give you an error, you can also goto safe mode with the f8 key on startup, choose safe mode, and then click yes at the prompt to start the system restore, pick a date and time the PC worked, and try that.If that doesn't work, you need to restore the PC to factory default state, by using or purchasing restore disks, you would have been asked to make them when you 1st powered on the PC, if you don't have the CD's call HP and order them.
Apr 20, 2009 | Computers & Internet
How do you turn off the sleep mode in a HP 3600 printer?
My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on.
Mar 25, 2009 | HP LaserJet 3600n Printer
Can't print a complete print job without problems
There may just be some type of configuration issue going on if you don't have a drive installed in this printer. If there is no drive installed the printer drivers may be functioning as if there's one present which results in this error. I'm providing you with a few possible solutions as it is more difficult to pinpoint an issue when you don't have access to the device.
If it is a configuration issue you can try these steps:
1. Mopier mode should be disabled.
Right-click printer then click properties.
You should find a device settings tab...scroll down to mopier
mode and make sure it's disabled.
2. Printer Hard Disk should be disabled.
Go to the Device Settings tab...scroll down to Printer Hard Disk
3. If you had to disable one or both features then the very last thing that you want to do is try printing a multiple page document to see if this worked.
If you check these two settings and find that both the mopier mode and printer hard disk are disabled then you can try this:
Click this sentence to follow the link to HP's driver and software page for the 4600 series printers. Find your operating system in the list and click on it. This will bring you to the page with drivers, firmware, and additional software provided for your printer type. Try downloading the drivers (unless you have the installation CD) and reinstalling the printer. Also, make sure that you have the latest Service Pack installed for your operating system. If you're using Windows XP then the latest Service Pack is 3.
Hope this helps. I work with HP printers and sometimes I have to try more than one solution before I find the right fix.
Please share your experience by rating this solution and thanks for using Fixya.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
My HP 2610 defalt has changed to fax instead of print mode
follow this trouble shooting steps your issue should resolve.
On Computer:
Click on Start >> Control Panel >> Printer and Faxes >>
check which Icon is enabled if Fax is Enabled Just Disable it By right clicking on it and Disable.
Now Right Click on Printer Icon then select " Use Printer Online"
then set it as Default Printer.
Now try to print your issue should resolve..
I hope it helps ...raj 9866486995
Raj....
Feb 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
When I click on "print" to print something I get a message "Unable to start driver for HPZipm12.exe(HPZipm12.exe). What should I do?
Please note that this is the first of two issues referred to in my previous response to your original posting. This addresses only the matter of the message received in regard to HPZipm12.exe. In order to solve the problem, I believe it is appropriate to gain a basic understanding of the issue that is creating the problem itself. This is as opposed to giving you a solution that simply directs you to go to this page, click here, and click there... Further, with an understanding of the primary problem, it becomes a little less difficult to dig through the mounds of material available on any given internet site that may not be as accurate as we may hope.
HP multi-function printers, such as your PSC2110, utilize a PML driver service. PML ("Printing Industry Markup Language") was a markup language designed for the printing industry (printers, publishers, paper distributors, and ink/consumable suppliers, for instance. This is similar to the XML language to be used primarily in the grahic industry (at the time of development).
The PML service basically handles bidirectional communication between the PC and the printer, therefore being required for such functions as scanning, card reader functions, certain copy tasks, usage of the HP Director software, and updating of printer item status in the related system tray tracking icons, etc. Unfortunately, certain versions of the driver have been associated with nearly constant problems, and specifically with specific software applications, such as Sage Accounting, or with "unable to start driver" errors at startup.
Based on my extensive research, there is one potential fix for this problem, with the second being to disable it. (Note that this assumes you are signed in and working as an administrator.) The first is to ensure that your firewall alows the task to communicate external to the PC. In other words, if the firewall does not allow the HP function to communicate through the firewall as an exception, it will be blocked, and will not function, thereby creating the result you see. Please review your firewall in detail, and HP recommends that all HP software be permitted to communicate as exceptions to the firewall.
The second manner of addressing this problem is primarily to disable the function at startup, changing the type of startup to manual. Per HP, most ("if not all") of the functions will continue to work as they should without the PML driver. Therefore, HP recommends that, should changing of the firewall/security software not achieve the desired result, that the driver be set to manual startup. This will have the effect of disabling it at startup, and will require that (should you attempt a function requiring its support) you manually start the service as necessary. (See HP reference: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01179939&lc=en&dlc=en&cc=us&product=79488&rule=14279&lang=en.)
There are a number of other references, should you desire same, but this was the most comprehensive and relevant to the problem at hand.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 08, 2008 | Office Equipment & Supplies
NUMBER OF COPIES
If you cannot print more than 1 copy, click on...
Start -> Control Panel -> Printers -> Right click on HP 1320 printer icon -> Properties -> Device settings -> Disable mopier mode (last option)
This worked for an HP 1300, 1320 and as well as an HP P2015d using the HP 1320 driver.
Apr 11, 2008 | HP LaserJet 1320 Printer
Access
Ah ... HP software is the worst ... if you are using XP or Vista simply use the built in wizards to scan or print ... If you really need the print center first check in my computer ... c: drive: program files... HP folder ... if the software is corrupt you need to reinstall which is a leangthy process with HP.... the best bet is to use the HP scrubber tool ... then delete all hp printer folders ... then run a registry cleaner (ccleaner) ... then restart and reinstall ... before reinstalling use the msconfig utility to disable all of your startup items (not safe mode) then reinstall
Mar 29, 2008 | Dell A940 All-In-One InkJet Printer
48 people viewed this question
Seeker5211
Seeker5211
