When you installed the new router your network addresses changed on your computers so you need to change the address on the printer to match the new network.
Does your printer have Network sharing capabilities? Some printers will allow you to share them, but still wont be able to allow you to print to them remotely. Secondly, if you have a server on your network, you'll need to check your router and make sure it's DHCP is not enabled and assigning IP addresses to nodes on your network. This can create communication problems if both DHCP servers are assigning IP ranges that are on completely different subnets
If you have done it properly there is no need to bridge networks because there should only be one. The entire idea of a repeater is to simply pick up the signal from the first router and rebroadcast the signal.If you had included the model of the repeater I could have been more specific but as it is, read this: Linksys Official Support Configuring an Access Point as wireless repeater
Difficulty: Moderately Easy Instructions Things You'll Need:·Wireless print server ·USB printer ·Ethernet cable ·Computer 1.Step 1 Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address. Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit. Step 10 Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
As an IT admin at a small school district I can attest to the scan in print issues via network with this model. Our eventual solution after HP provided little help was to USB it to a workstation and then share it with limited rights to users. It was most stable otherwise with only bare drivers loaded and not using any associated HP software
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Are you connecting via usb or ethernet cable?
Through usb you need to install the driver on the pc it is connected to. Then share it.
Through ethernet make sure your CAT5/Ethernet cable is connected from your printer to your router/switch. Through the menu on the printer Print the network setup.
Then from your web browser type
http://ip address of printer from the network setup page
If you can then you need to add the printer driver on your pc and use a tcp/ip port to print to it through the network.
I think I have solved this, any way it worked for me.
Turned off printer and turned off wireless router made sure no computers are on.
Restarted printer make sure wireless settings are installed in printer then restart router.Once router is up and running switch on computer and you should be able to print.
Hope this works for you.
Hi dreaddymck
I need a little more information on the setup. Is there a router in your network? If there is, is your PrintServer connected to the router and your computer is attempting to connect to the printserver through the router? If there is no router and your PrintServer is connected to your printer via the USB port and your computer is connected to one of the ports on the PrintServer via a cat5 cable, I would check to see whether you are actually communicating with the PrinterServer by pinging its IP address from the computer. If the ping is successful, then I would look at the printer properties in your computer's printer control panel and check the port configuration. Usually it is shows the IP address, port 9100 and port protocol is usually set to RAW. Otherwise I would attempt to reinstall the PrintServer using the CD originally provided. It appears to me that the server may not be publishing its IP address on your network.
--RoadHawk
You need:
* A wireless-enabled computer. Many computers made over the last three years are already wireless capable, or they can operate wirelessly with adapters.
* A wireless router. This will serve as your Wi-Fi access point, the hub of your network.
* Broadband Internet access. While you can use your wireless router without any Internet access at all, or use dial-up, experts agree that there?s real value in accessing online content via DSL or cable and making it available to every computer in your house. The cost of doing so, like with the hardware, has dropped dramatically in the past several years.
When you set up your network using the wireless router, you?ll need to identify that network on each of your wireless computers and during the installation process for your Lexmark wireless printers or all-in-one devices. You?ll be asked about your service set identifier (SSID), which is basically the name of your network. Don?t forget to consider the security of your network early in your decision process.
* Common security types for networks include WEP, WPA and WPA2, and there is usually also an option for no security. At a minimum, you should look for WPA or WPA2 security and follow the manufacturer?s instructions to encrypt your signal and set your own password. A password isn't mandatory, but if you don't use one, it's far easier for others to access your network, and potentially your computer.
