Question about Cisco 7940 IP Phone
Cisco IP phone 7941-- No power on the phone just a blank screen after I installed a headset, I did unplug the headset but is not coming back on.I also tried a new Ethernet cable but no luck. What can I do to get it back on? Please.
  • Ryan Paterson
    Ryan Paterson May 11, 2010
    I'm pretty sure that the Headset is not what caused your problem. Quick question for you though, are you using a Power Supply with your phone, or is it PoE (Power Over Ethernet). If it's got a power supply, try a different one (if avail.). If it's PoE, try the phone in a different location.
    Unfortunately, if neither of these helps, then I think you've shorted your phone. It could have been caused by a faulty headset, but I doubt it. If that is the case, then the headset wouldn't work on any other phone, is this correct?
    Scholar:
  • 97 Answers
Is this in the same switch as when it was last working? If not, it could be that the new switch that it is being plugged into is not a Power Over Ethernet switch (if you do not have a power supply for the phone that you are using).
The other issues could be that the PoE function has been switched off on that port, the port is disabled for some reason (check for errdisable status in a sh int [interface name and number] command) or just simply that the port is shut down (test this by plugging in a computer and see if it communicates ok.
Hope that this has helped!
Posted on Oct 17, 2010
  • 3 Answers
Is the phone connected to a POW (Power Over Ethernet)Cisco Switch? Check the model number of the switch with the Cisco web site www.cisco.com
Have you check whether there is power available on the switch?
enter "show power inline" at the command prompt.
Does the phone work without the head set?
Does the same thing happen when you plug in the head set on another phone?
Posted on Sep 17, 2009
I need to modify the settings of my cisco ip phone 7941
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Aug 04, 2015 | Cisco 7941G-GE IP Phone
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
Why can't I connect my corporate Cisco IP Phone 7941 to a switch? I can connect a switch to Cisco phone switch and connect multiple devices. But the phone will only work when connected directly to the wall...
Connecting a hub or switch to the "PC" port on the back of the phone is not a recommended best practice by Cisco as the IP phone does not support spanning tree protocol.
Sep 28, 2010 | Cisco 7940 IP Phone
When I plug the 7941 cisco phone up to our network on a POE switch, it responds with the message "Ethernet Disconnected", but when we plug another Cisco 7941 phone to the same line it works perfectly... We...
I would check your duplex settings. Often, if you hard code the duplex settings or have a mis-match; one end may not talk properly. Also, have you tested the wiring? Do you know the ethernet is okay for sure? TechRx, Inc. - techrxgb.com
May 12, 2010 | Cisco 7941G-GE IP Phone
CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Jan 07, 2010 | Cisco 7941G IP Phone
CISCO 7941 IP PHONE disconnect you out after certain time
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Apr 06, 2009 | Cisco 7941G-GE IP Phone
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Oct 28, 2008 | Jabra T5330 Wireless Headset
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
1,551 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
