Question about Fellowes Powershred 120C-2 Shredder
Basket ajar light stays on even when the door is closed. How do we get the light to go out?
  • 328 Answers
The door sensor could be bent or broken. There is also a thin piece on the door that pushes the sensor switch. Check to see if it is broken. Try pushing a thin object into the sensor **** opening and listen for a click.
Posted on Jun 22, 2009
Tip
Door ajar light stays on?
Does your vehicles door ajar light stay on all the time?
A quick and easy solution that fixes it most of the time is to spray WD40 into the latches. Yes WD40. Spray some into the latch, don't be shy you can wipe off the drips, then open and close your door about 5 times. Spray some more in there and open and close the door a few more times. Do this to each door and even the hatch. You will be surprised when the interior light finally goes out and the door ajar light finally shuts off.
Hey and while you are at it why not give the hinges some lovin too, spray some WD40 in there when you spray the latches. Might as well get rid of the creaky door at the same time as turning off the door ajar light.
Good luck and have fun.
on Jan 05, 2011 | Wd40 Open Stock Lubricants 10110...
Doorajar liht and beeper sounds
It can be issue with faulty sensor or a wiring issue.Troubleshooting is required.
Click the help link shown below:---
Door Ajar Light and Dome Light Remains ON? http://whoisbyme.blogspot.in/2012/06/2003-mercury-sable-door-ajar-light-and.html
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Thanks.
Jun 26, 2012 | 2002 Ford Explorer
My door ajar light is on but all doors are closed and the overhead lights keep going on and off
You have a bad door ajar switch on one of the doors. It is shorting out and causing the lights to flicker and the door ajar light to stay on.
Feb 01, 2011 | 2002 Ford Explorer
Door ajar dash trouble and dome light stays on even if all doors
The door sensors will need to be replaced. A screws can be removed and then a wire can be taken of and you then can replace the switch.
Sep 25, 2009 | 2001 Ford F250 Super Duty Super Cab
Door ajar light & washer fluid light & bell dings,
sound like your fluid sensor may be stuck or bad if light stays on try tapping the washer motor on the resevoir if it goes out faulty sensor as for the door ajar light it might have bad connection with sensor saying the door is closed local dealer should be able to troubleshoot sensor
Aug 23, 2009 | 2003 Ford Expedition
2005 f150 "Door Ajar Light Always On.. Even with all doors shut..
What happens when you remove both switches, and wires? What happens when you use a jumper wire acros both wires, on both doors?
Feb 25, 2009 | 2005 Ford F-150
Door ajar light on
The drivers side door switch goes bad all the time on those, try replacing or check if its sticking.the small little button int the door jam.
Feb 01, 2009 | 2002 Ford F250 Super Duty SuperCab
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
Door ajar indicator stays on
you may just need to adjust your door jams they may not be closing properly, the other thing you can try is opening one door at a time and putting your finger on the switch usually in the lower l/h corner of b piller and see if the light goes off if not this may be the problem and replace the switch
Dec 18, 2008 | 2003 Toyota Corolla
Fellowes Powershred 120C-2 Shredder Logo
311 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
