Question about Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer
Kyocera FS4020DN won't add ink
I just replaced the drum and developer in my Kyocera FS4020DN and put in a new toner cartridge. It says "Original toner installed" and won't add ink - copies are blank.
  • 40 Answers
SOURCE: Kyocera 1810 drum replacement
If you have some mechanical skills and a steady hand you can change the drum. However it worth the money to pay a "pro"to do it. Also you may want to replace the cleaning blade too.
1. Open the front cover - where the toner is.
2. Remove the black cover - 2 screws
3. Remove a little stopper at the bottom of the drum unit + 1 screw
4. Disconnect the drum unit cable.
5. Take off 2 screws which secure the Drum Unit.
6. On top of the Drum unit you should see 2 white plastic stoppers - front and back side ends - You have to push them inside to keep the cleanng blade away from the drum.
7. Remove the MCH assembley - 1 screw.
8. Remove the front separation claws + plate - 2 screws.
9. Remove the Drum Shaft
10. Replace the Drum
There are few details about how to manipulate a Drum - Do not touch the surface, do not expose it to intense light...
8.
Posted on Jan 12, 2009
  • 66 Answers
SOURCE: i already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
Posted on Jun 22, 2009
n25an
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
Posted on Dec 24, 2009
shawn38
  • 200 Answers
SOURCE: my kyocera km 1500, it says
E33 means the copier is out of toner. Try tuning off and let it cycle a few times, if you ran it completely out some times it takes a few cycles to get running again.
Posted on Feb 18, 2010
shawn38
  • 200 Answers
SOURCE: Instructions required to replace the maintence kit
You must unplug your printer before doing any work and be very carefule not to damage any of your parts.
(1) Precautions
Be sure to turn the power switch off and disconnect the power plug before starting disassembly.
When handling PWBs, do not touch connectors with bare hands or damage the PWB.
Do not touch any PWB containing ICs with bare hands or any object prone to static charge.
Use only the specified parts to replace the thermal cutout. Never substitute electric wires, as the printer may be seriously
damaged.
When removing the hook of the connector, be sure to release the hook.
Take care not to get the wire caught.
(2) Drum
Note the following when handling or storing the drum.
When removing the drum unit, never expose the drum surface to strong direct light.
Keep the drum at an ambient temperature between 0 °C/32 °F and 40 °C/104 °F and at a relative humidity not higher than
90% RH. Avoid abrupt changes in temperature and humidity.
Avoid exposure to any substance which is harmful to or may affect the quality of the drum.
Do not touch the drum surface with any object. Should it be touched by hands or stained with oil, clean it.
(3) Toner container
Store the toner container in a cool, dark place.
Avoid direct light and high humidity.
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developing unit.
4. Check or replace the developing unit and refit all the removed parts.
(2) Detaching and refitting the drum unit
Procedure
1. Remove the developing unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
(3) Detaching and refitting the fuser unit
Procedure
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the fuser lock (gray colored) on the rear unit and the fuser unit is separated from the rear unit (rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all the removed parts.
Place the fuser unit on the rear unit (rails) and push the fuser lock so that the fuser lock catches the fuser unit.
Do it for the both ends of the fuser unit.
(4) Detaching and refitting the transfer roller and separation charger brush unit Procedure
2. Remove the drum unit.
3. Slide the paper chute guide and unhook the hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the both bushes.
6. Release four latches and then remove thecseparation charger brush unit.
7. Check or replace the transfer roller and separationccharger brush unit and refit all the removed parts.
CAUTION: Note the following, when refitting the separation charger brush unit.
A. The separation charger brush unit is inserted into the two projections of the frame and does not run on to the projections.
B. The separation charger brush unit is firmly in contact with the separation charger plate of the frame.
The last things to replace would be your rollers which just pop in and out.
Posted on Jan 22, 2011
Kyosera 2200 display add toner problem when addedva new toner ?
Kyocera products are very particular when it comes to the toner used if you are using toner that is not model specific Kyocera toner you can have this problem you can try Kyocera toner now but you may have destroyed the developer in which case you need fresh dev and model specific Kyocera toner don't use toner that says for use in look for the Kyocera logo on the box
Apr 01, 2018 | Kyocera Office Equipment & Supplies
Hi there, I have a Kyocera FS-820 and have recently replace a new ink cartridge but the printing remains patchy and not good, can you advise what could be causing this?
it sounds like the ink might not be coming out flowing it might have some air pockets ,i say take it out ,shake up then reinsert make sure it alright and tight
Apr 13, 2017 | Kyocera Office Equipment & Supplies
Where is developer unit in kyocera fs 1370dn
the developer unit for this printer looks like this.
26367533-y50xtmg3b3sor10el1acrrt1-1-0.jpg The unit can be found under the toner cartridge.
Here is a link on how to remove the toner cartridge.
okm2000 de Kyocera FS 1370DN 1370 1350 1320 Tonerwechsel Kopierer Drucker...
Best regards,
Marius
Nov 22, 2016 | Kyocera FS-1370DN
Can I use Kyocera toner for utax Copy machine?
take the cartridge along to a ink refiller shop and ask them as they have a good knowledge of product inchangeability
Aug 12, 2016 | Kyocera Office Equipment & Supplies
How to clean kyocera rollers
drum unit main charge failure. non compatible toner in the developer unit.
Jun 18, 2014 | Kyocera Mita Mwave Generic Toner Cartridge...
We have a Kyocera Mita KM 1510 and I am getting an error code C710 and the add toner light is on. I put in a new toner cartridge but the error message and the light are still on. Any suggestions?
C 710 is a Toner Sensor Problem
Defective toner sensor - Replace toner sensor
Poor contact of the toner sensor connector terminals - Reinsert the connector. Also check for continuity within the connector cable. If none, repair or replace cable.
Developer problem - Replace developer.
Apr 07, 2011 | Kyocera Mita KM 1510 Laser Printer
Kyocera FS_2020D. Problem is: Call service 7410:0006336
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective circuit board. Typically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmly on the drum which is located behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
Feb 18, 2011 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
May 07, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Missing developer unit
Generally this printer can be separate into 4 major part: Printer body, Toner container, Developer unit and Drum unit. The developer unit is the unit where the toner container "mount" on it and it should be removed to allow cleaning task every time the toner container is replaced.
U may get this error message if the developer unit is not install properly after u replace a new toner container. Just lift the developer unit together with the toner container out of the printer and then insert back properly into the machine.
YBC (/\)
Jun 03, 2008 | Kyocera FS-920 Laser Printer
Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer Logo
50 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
