Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have a 85hp Yamaha outboard motor. It starts easily, but wont shut off (with the key or kill switch).
  • Anonymous Mar 25, 2014
    motor wont start from ignition,have power to switch,but motor wont start,with key,it will start if I jump the the starter,and will shut dowm at switch how do trouble shoot this?
  • 23 Answers
Sounds like the ground wire in the control box where your key switch is located is broken are disconnected. check the wiring harness plugs if it is unpluged are not pluged tight it will not shut off
Posted on Jun 19, 2009
Mariner 50:hP outboard starts only when you flip kill switch
Check the installation of the switch. It sounds like it is installed upside down, or the terminal wires were reversed. You may be able to easily switch the leads to make it work correctly.
May 19, 2015 | Light Outboard Motor Boat Bass Fishing...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
Outboard problems
Broken connection in the wiring harness(loose)
Jul 28, 2014 | Yamaha Tilt Trim Motor, 40-50 HP Outboard
Motor wont turn off with key
Could be broken wire in loom,or bad connection in loom plug or faulty ign switch which is very unlikely
Mar 17, 2014 | Clymer Marine Maintenance and Repair...
2002 yamaha 150 outboard wont shut off with key
Broken wire in loom,white wire,bad connection in loom plug,if it switches off with kill switch,then it points to ign switch
Mar 15, 2014 | Clymer Marine Maintenance and Repair...
Mariner 40 hp outboard
Faulty kill switch faulty ign switch,how old is motor,is it electric start,isit ayamaha mariner or mercury mariner,if Yamaha disconnect white wire from cdi
Dec 31, 2013 | Boating
Yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Sep 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Overheat sensor keeps going off on our yamaha 85hp outboard. Water pump has been replaced, thermostat, and sensor. Motor does not seem hot and water is coming out. Help please.....
Hello there:
when you changed out the sensor did you have the codes cleared from the computer brain this is common on outboards. contact your local dealer for further asistance .
best regards mike
Jul 25, 2009 | Sport & Outdoor - Others
Turn the switch off motor keeps running
It sounds like there is a short in the alternator or wiring for alternator. You are continuing running with the battery cut off. But the outboard generates its own power and its finding the way to the ignition. As for grounding, you may be idling too high for a quick shut off.
Jun 18, 2009 | Boating
Motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
Feb 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
947 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
