Question about Dishwashers
The water is not coming into the machine and the tablet is still dry even though it comes out the draw, the dishwasher makes a noise but no water s getting into the machine
    Sergeant:
    Champion:
  • 240 Answers
Check your water inlet hose and any filters attached to it. Some hoses have a little turnkey tab to turn them off. Make sure this has not accidently gone into the shut off position. If you pull out the machine you will hear if the water is coming in through the inlet hose.
Posted on Jun 18, 2009
6yr old machine....last couple of days has completed wash/dry successfully and end illuminated however it then makes a whirring noise as though program is still operating even if door is open, the sound is...
If I am not mistaken, your dishwasher comes equipped with a water softener unit.
At some stage the regeneration cycle for the water softerner takes place. I am assuming the sound you hear is the solenoids of the regeneration system working.
If you are unsure you can refer to the user manual or this site for details. You will need to provide me the full model number in case you want further information.
Jul 05, 2011 | Bosch 24 in. SGS43C12 Classixx...
When in use, my dishwasher at times, makes a lot of repeating noise and it appears to tick.. th digital reading on the right blinks CL CL CL CL then HOT then goes back to tell you the remaining time, and...
Some dishwasher noises are normal, like the hiss of water rushing through the water inlet fill valve, or the hum of the pump motor, or the slosh of water. But if your dishwasher is making strange sounds or is unusually loud, it's time to investigate. A thumping noise could be the drain line vibrating against the cabinet; a grinding noise could be caused by a popcorn kernel being stuck in the chopper blade area of the dishwasher.
The CL is normally indicated child lock has been activated.
Dishes typically dry by the end of the dishwashing cycle, with one exception-plastic items. Because plastic doesn't retain heat like glass, ceramic and metal do, you'll almost always see drops of water on plastic items after the cycle finishes. Rinse aid helps water drain off all dishes so they dry better. Make sure that you fill that rinse aid dispenser when it's empty. A heated dry setting also is an option to enhance drying. You may have this option turned off to save energy, but if your dishes aren't drying as well as you'd like them to, you might want to consider turning it back on. Consult your owner's manual and select the cycle options that fit your needs and your energy usage goals. If your dishes don't get dry even though you've selected the heated drying option, then the heating element could be broken or the high-limit thermostat for the element may have tripped in error, preventing the element from heating. A malfunctioning vent or drying fan could also prevent dishes from drying. Check out this troubleshooting video that could help you correct a drying problem: Dishwasher Not Drying Dishes Video.
Oct 26, 2017 | Frigidaire FDB1502RGS Built-in Dishwasher
The dishes just don't get clean. I know this isn't much to go on, but that's it.
Is the water hot? (make sure hot water is available to the machine at the start of the cycle by running the sink faucet until it is hot) Are you using the internal heater? (check the control panel for this feature) Are you using the entire cycle? (time) We are not talking about baked on food here are we? Dirty dishes that have dried?
Dishwashers cant remove baked on food no matter what the advertisement said. If the food is dried on, there is a better chance but ... dishwashers work best with freshly dirty dishes. If the food is dried, at least let them soak in the dishpan for a few minutes before you put them in.
How are you arranging the dishes, can the water reach all surfaces? (Think tempest in a teapot).
Have you tried other detergents? My preference is liquid though others may prefer granulated or tablet. I also like to use a product called Rinse-Aid.
If you have considered all these ideas and the dishes are still dirty ... there may be a mechanical fault with the machine. Is it making the proper noises?, Filling and emptying properly? (listen to it)
I hope you find these suggestions helpful ... Thanks for your visit today.
Jan 27, 2011 | Amana 24 in. ADB2500AW Built-in Dishwasher
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
KUD101FKSS Kichen aid dishwasher does not work.
There are three tabs that are holding the whole assembly, accessible from the bottom...they need to come out. Only then you can remove or even move the assembly...
Apr 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishes not coming out clean
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Nov 12, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher probs
It sounds like you have eithwer a low water problem (ie..Clogged inlet valve ) or your heater inside the unit is bad are they drying ok one other thing to do is run the hot water at the sink first to make sure the cold that is in the lines from the water heater is not filling in the unit try those things first
Jan 24, 2008 | Zanussi 24 in. IZZI ALU Built-In...
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
