Question about HP Compaq nx8220 Notebook
Removal of casing on HP nx8220
I have a HP nx 8220 that is completely dead.I am familar with Desktop repair but I cannot release the rear casing.Can you help?
  • HP Master
  • 32,281 Answers
First of all remove all your components ie. RAM, hard drive, battery, CD/DVD drive etc. Sometimes there are screws located in the area where these components are located that secures the top and bottom halves of the case.
I suggest that as you remove the screws from the bottom of the case you take a note where the came from as some of the screws are different lengths.
There may be s strip panel between the top of the keyboard and the LCD screen, remove this first, it will be clipped in place and held with screws from the bottom of the laptop.
Next the keyboard should removed and keyboard cable.
Look closely for screws hidden behind plastic stick on covers, you need to use a sharp thin blade to lift off these covers to reveal the screws behind the covers.
The top and bottom halves of the case is usually held in place with plactic clips, start at an opening and carefully pull apart until a clip releases and the work along that edge to release more clips. Continue along each edge until you separate the case.
The LCD screen is usually secured with screws on the back edge of the laptop and possible with screws near the edge of the motherboard. Take care to disconnect the video connector.
The motherboard needs to be removed from the bottom half of the case so you can access the power connector.
Take careful note where you remove each screw as you need to put them back in reverse order.
Best of luck, have fun.
Posted on Jun 19, 2009
How to reset bios password hp nx8220
one way is to remove the coms battery for a couple of mins then put it back,not saying it will work but worth a try.
Jun 29, 2014 | HP Compaq nx8220 Notebook
Hp nx8220 starts but will not load windows xp
Hi there, if you have the recovery disc try that first. However, I had to deal with a similar problem on a FUJITSU LIFEBOOK, and after trying many possible solutions it turned out to be - hard disk failure, sorry. Hope this is not the case for you.
Jan 22, 2013 | HP Compaq nx8220 Notebook
Speed up HP compaq nx8220
Many reasons may cause your HP Compaq computer running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues. Hope this helps!
Feb 10, 2012 | HP Compaq nx8220 Notebook
I have a compaq nx 8220 from 2006 everything seems to be perfect till last week. 1.when i press the start button to open the display goes black and nothing is happening. 2.if i manage to start it ...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP Compaq nx8220 Notebook
I forgot bios password! I tried to remove bios battery but it didn't work! hp nx8220
Removing the RTC battery will not do it.
Laptops these days are very secure. You need to call HP and prove ownership and they will give you a backdoor password.
Regards.
Oct 20, 2010 | HP Compaq nx8220 Notebook
I forgot my power on password on HP COMPAQ NX8220.How can i remove it?
Unfortunately, you cannot remove the password without sending it to an HP repair center or other extreme methods. As mentioned in the repair documentation for your laptop found HERE.
"WARNING: If you forget the power-on password, a repair at an HP-certified repair center is required to reset the computer. Please contact HP to schedule a repair. This service is not covered by the warranty."
A detailed explanation is provided by one of our Tip writers, pappapumpdaf, who wrote this helpful document on the subject.
http://www.fixya.com/support/r4342847-laptop_cmos_hard_drive_passwords_whole
Oct 12, 2010 | HP Compaq nx8220 Notebook
Hp compaq nx8220 (insert smart card into reader)
you need to push and hold control, alt, and delete to initialize the start up.
at this time it will ask you for your username and password.
May 31, 2010 | HP Compaq nx8220 Notebook
Regarding HP compaq nx 8220, there's no cable, what can i do? where can i get it?
Search eBay to see if you can find one there. You can probably find one pretty cheaply there.
Jul 07, 2009 | HP Compaq nx8220 Notebook
I Forget the BIOS setup password
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
Feb 18, 2009 | HP Compaq nx8220 Notebook
HP Compaq nx8220 Notebook Logo
448 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
