Question about Sewing Machines
Efka v810 vario control - Sewing Machines
I purchased a juki hzl-T600 used, I need foot control and owners manual can you help me
you can probably get a user manual by going google and typing in -- user manual for juki model hzi-t600 sewing machine--- and downloading any pdf versions
as for the foot control, most are either resistance controllers or electronic controllers so talk with a service dealer or a sewing machine repair shop ti get the pedal control or to find out where you can get one . the problem will be the plug fitting for the pedal control into the machine or motor
Dec 20, 2016 | Juki Sewing Machines
Electronic foot control on My Elna free arm model SU is not getting power to the machine from the electronic foot control. The light comes on, but the control will not provide power to the machine.
take the foot control in to a sewing machine repair shop and have it tested
earlier models were a simple resistance variation but later models are electronic control
it could be a simple broke connection in the control
Sep 04, 2016 | Elna Sewing Machines
Why wont the pedal control work?
It might be busted, bring the machine and foot control to a Brother repair shop so they can try your foot control on another machine, and so they can try another foot control on your machine.
It may be the controller, or the wiring, of the plug or the....
Oct 17, 2014 | Brother Sewing Machines
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
HOLA! HE INTENTADO ENHEBRAR MI ULTRALOCK DIFFERENTIAL FEED Y NO LO HE LOGRADO. POR FAVOR, DIME QUE PUEDO HACER. GRACIAS.
Tienes la manual?
Lo puedes descargar en el sitio web de Singer.
http://www.singerco.com/accessories/manuals.html
Pone 14SH645 y hacer clic en search.
En el siguiente pagina aparece varios opciones, elige el ultimo y hacer clic en free download!
Espero que este ti ayuda.
Sep 21, 2010 | Singer 14SH654
My foot pedal doesn't seem to work when I push it down
Probably needs a new foot control. Bring the machine and the foot control to a shop, they can test it to see if it is the control, the wires from the control to the machine, or something else.
The control and wiring are sold separately, the control is often cheaper than the wires from the control to the machine, don't throw anything away until you have someone look at it first!
They will remove the non functional foot control from the wiring and put a new one on. A new foot control is not expensive.
Feb 09, 2010 | Elna Sewing Machines
Old model Bernina 830, running ok, then kept running, won't stop. disconnected cord, disconnected foot control, plugged cord into motor, motor runs without foot control. Reconnected foot control, motor...
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Jun 25, 2009 | Bernina Sewing Machines
Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Feb 02, 2009 | Sewing Machines
Schematics Required
hay guy,
i also need the diagrams.i tryed many way to find it.but it dosent work.
anyway im repairing efka & quick rotan by myself without any diagrams.
if you like i can share my knowledge with you.
email me .
first sms me .00940772532280
nuwan
Aug 12, 2008 | PfaFF Creative 7570
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
