Question about Samsung RB215LASH
Freezer door won't stay closed. Doesn't seal properly
2 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: We have a brand new
  • if the installers have taken the doors off during the delivery then they may not have realigned the door properly.
  • you can try to adjust the top door hinge or move some spacers from top to bottom or bottom to top.
Posted on Jul 05, 2008
How do I fix a freezer door that pops open when the refrigerator door is closed ?
Good Afternoon Friend, this is Z. I appreciate your post!
Often when one door is closed and the other opens, it is because either the hinges are damaged or your refrigerator has a poor door sealed. Trying checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. If the gasket is not sealing properly, it may possibly near replacing. Since there are cost differences in parts it is always a good idea to have a certified technician properly diagnosis your appliance. Best regards!
Aug 05, 2014 | Frigidaire Refrigerators
I have a Sears Coldspot chest freezer Model #1869. The door doesn't seal properly and ice builds up within the door and the seal becomes even worse. The freezer itself works fine.
A precut seal will be expensive so please don't expect the price to be reasonable should you find one. Sears uses a longer number to list model numbers like 312.215478 as an example. Where can I find my model number? Let me know if you have questions, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Amana Br22tw refridge door won't stay closed
Check all the screws for the hinge and be sure the door is lining up properly.
Oct 23, 2012 | Amana ABB1927DE Bottom Freezer...
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Need gaskets for CSX20E Hotpoint side by side
Seals don't lose their magnetism. Check the door closes all the way round and adjust the hinges if it doesn't sit straight. Check there isn't a relief valve frozen up or blocked (it allows air to escape when the doors are closed). Check the drawers are fully pushed back in and not stopping the door closing properly
Sep 11, 2012 | Hotpoint Refrigerators
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
Freezer won't stay shut
If you want a part number for the replacement door gasket please provide a complete model number here so I can give that to you or you can look it up yourself at www.searsdirect.com You must have your model number. (sample 110.XXXXX etc)
The magnet is inside the door seal itself. If the seal is damaged replacement is your only option.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Refrigerators
Refrigerator door will not stay closed
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Sep 25, 2009 | Sub-Zero Bottom Freezer Refrigerator
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Samsung RB215LASH Logo
63 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
