Question about Sony Audio Players & Recorders
Sony tc k311
Cassette won't eject
  • Sony Master
  • 1,258 Answers
The mechanism driven by either cam or flywheel assist has a slipping belt and or hard dried grease. The deck need to be serviced that is why this happens.
Posted on Jan 02, 2015
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
  • 4234 Answers
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Posted on Oct 07, 2008
INTERLOGIC
  • 326 Answers
SOURCE: i have a tape stuck in my sony tc we645s cassette deck
try factory restore settings
Posted on Apr 14, 2009
  • 1348 Answers
SOURCE: cannot get cassette doors to eject
the motor that drives the mechanism is jammed or burnt out.if you remove the cover and turn the big metal weights driven by the motor,the unit will dock the assembly and the door should open.
it thinks it is playing a tape and that is why the eject doesnt work
Posted on May 26, 2009
welcomejee
  • 10594 Answers
SOURCE: NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Posted on Dec 25, 2009
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
Apr 21, 2012 | Sony CASSETTE DECK Single Dual Cassette...
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Feb 18, 2012 | Sony TC-WR565RM Single Cassette Deck
I have a duel cassette player sony model # TC-WR 565. The doors will not open and both casettes cannot be removed even after prying the door open.
Mine did that - you will have to patiently keep pressing the clear / stop / pause / etc and even power cycle a few (or many) times and finally you will hear the mechanism release the cassette. Once you hear that - you will be able to eject the cassette. After that go replace the belts.
Dec 29, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Jun 17, 2010 | Sony TC-WR565RM Single Cassette Deck
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
