Question about NexxTech Lands Phones
Megaphone 3208219 want to know the wire schemetatic for the switch to the circuit board and the 4 pin jack for the mike
Wires broke off
Open SKy
  • 620 Answers
SOURCE: My conrol cord has its pins distorted
Well Friend,
What is the brand , name, model of your mobo, and what "control" is what you talk about.
Posted on Nov 25, 2007
map9966
  • 2351 Answers
SOURCE: power switch went bad. need to know which pins attach to which wires
Looking at the front of PC remove the left side panel. Now looking in at the board. There are two rows of pins in the lowest right hand corner of the board. Your PWRSW is your power switch. Its a two pin connector. The ground wire will be black or white. The ground faces to the right & connects at pin 4 counting from right to left. Power switch takes up pin 4&5.
All done. If tech switched the wires by mistake than flip the connector 180*.
Posted on Jan 01, 2008
  • 35 Answers
SOURCE: phone jack wiring
Its typical in apartments for the phones to come in through a single source and then fan out to other wire leads to the rest of the phone jacks in the place. However, I think its odd that your 'source 2' has 9 wires. I'd expect 8.
One idea is to take off a phone plate in another room and see if the wire colors on source 2 or 3 match the unknown source wires. If so, then just match the wires that connect to the same plugs in the plates.
Posted on Jan 26, 2008
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: 02 sportster 1200 brake light not working
if you have power at the harness pin but not the light then your problem could be a cut wire grounding to frame between connector and light. you did not say what kind of light you have. a regular filament light check the socket as they sometimes go bad due to vibration, if it is a led light, look for a bad componet on the circuit board like a open resistor or such. if you are handy with a soldering iron, you can repair it pretty cheaply.
Posted on Aug 27, 2008
How do I fix the injectore wire on my 1999 durango?
Depends where it is broke at. If it is broke at the head where it connects to the injector you will need a new wire but if it is broke back say two inches just use a wire but connector to repair it.
Jun 27, 2014 | 1999 Dodge Durango
Spark plug wire failure
Put new one if not catalytic con. will be next.Could cost $500.00+
Jun 19, 2013 | Cars & Trucks
I need a wiring digram for a rk 56 inside the mike my wires are broke need to know were to put them back connex 3300hp
  • With the switch sitting as it is in the picture below (actual switch recessed tho the right. Soldier the wires in this order.
  1. Black
  2. Red
  3. Lite Blue.
  4. Dark Yellow (This yellow wire comes from the mic cord itself)
  5. Shield.
  6. Lite Yellow. (This yellow wire runs off to the side of the mike to the electrical components inside the mic)
  • Standard 4 pin Cobra mic tip to run it to that Connex.
  • Pin 1 - Shield.
  • Pin 2 - White.
  • Pin 3 - Red.
  • Pin 4 - Black.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 05, 2011 | Connex 3300 240-Channels Base CB Radio
HOW DO I INSTALL ROGER BEEP ON A GALAXY 33 CB RADIO
Does the roger beep come with instructions? It can vary between beep boards.
Typically it gets installed inline with the mic jack.
There is a wire or pin on the board where the tx wire, and the rx wires go.These wires get disconnected from the mic jack, then a wire goes to the tx pin. Then there is an audio wire that gets connected to the audio wire of the mic jack. Then the black wire to ground, and the red wire to switched 12v right off the power switch.
Here is a schematic of the board connected to the mic jack so you know what pin is what.
Again, I would need to know what roger beep board you would like to install.
Feb 22, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
I have a cobra 148gtl with 5 pin side plug for mic.Im trying to wire a superstar dm 1000 echo mic to it,red,yellow,blue,white,& unsheilded wires dont know were they go.???????
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
Jan 20, 2010 | Cobra Radio Communications
Lands Phones Logo
32 people viewed this question
Top NexxTech Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a NexxTech Lands Phone Expert? Answer questions, earn points and help others
