Question about BOSS AUDIO SYSTEMS 615UA
Back left speaker does not work correctly - BOSS AUDIO SYSTEMS 615UA
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
May 01, 2014 | Onkyo TX-DS787 Receiver
Left speaker suddenly stopped working
I think it's a software problem. Unistall drivers. Restart. Reinstall drivers. Restart. Check settings.
Mar 27, 2013 | HP ProBook 4730s Notebook
I dont kno the wiring colors for my 2000 taurus radio
All you need to do is get the power, ground, and antenna hooked up then start with two colors matching, example: one purple and one black with purple line hook those up to a matching speaker wire then turn stereo on and go to balance setting choose back left if speaker does not sound then go back right and if speaker does not sound then try front speaker right and then left once you find correct speaker move on to next two matching remember to. Mark wires FL or fr or bl or back right. Good luck
Sep 10, 2011 | 2000 Ford Taurus
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
Apr 03, 2010 | Logitech X-530 Computer Speakers
Left speaker suddenly stopped working correctly.
check the plugin going into the back of the computer. it might be loose and only sending the audio to the right channel. Otherwise, check the connections in the back of the speaker.
Jul 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
Speakers not working
Did you try other speakers (that you know work correctly)?
Did you ensure the speakers were plugged into the correct place (wall and back of computer)?
What does your Device Manager say for this device? To get there, right-click on your My Computer icon, select Manage. From there, look in the left hand column for Device Manager. If you select that, It will display information about devices installed on your machine. Look for a red X or a yellow exclamation point.
Let me know what you find or if trying what's above solves your issue.
Derek
Mar 06, 2009 | Dell A215 Computer Speakers
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
Left side speakers only one working
Have you reset the settings in the system to 5.1?Are the rest of the speakers working? Go over the wireing yourself just unplug one at a time and reseat it on both ends system end and speaker end it may just be that when he put it together again one of the wires wasn't set back just right.
Jul 14, 2008 | Onkyo TX-DS676 Receiver
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
BOSS AUDIO SYSTEMS 615UA Logo
14 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Jerry Umali
Steve Sweetleaf
Steve Sweetleaf
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
