Question about Panasonic Office Equipment & Supplies
Problem panasonic pt 61lc27
Will any other bulb work for model PT-61LC27?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 15, 2015
SOURCE: Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
This is a link to AVS for Panny PT-50LC (LCD) which I assume must be the same for the DLP.
With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds. The TV will be turned on and it will have a screen of status data atop an active TV channel. To get out of this mode TURN OFF your TV.
This initial "SERVICE MODE 1/3" screen shows -
LAMP OPERATION TIME
TOTAL :
CURRENT LAMP:
OSD DISPLAY :
LON COUNT :
Posted on May 12, 2008
SOURCE: I have a panasonic model
Hi, I have the fix for you....EXIT out of the message telling you to reset you meter. Now you need to push the - vol (neg vol) button on you set, at the same time push the split button on your remote (very bottom of the remote is the split button with the vcr controles) You need to push these at the same time for 20 or more seconds and you will recieve a message that the metter has been reset. Exit out of that message and all should be fine. Took me about 15 minutes to get to a tech to walk me through it.
Posted on May 14, 2009
projdoc
  • 2237 Answers
SOURCE: Panasonic PT-60LCX64. What would happen if you
you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
Posted on Nov 12, 2009
Testimonial: "Thank you very much. I am in the process of replacing the whole casing with the bulb. I just wanted to say that I have had this TV for 5 years."
stecon3248
  • 57 Answers
SOURCE: how to lamp reset in
It's in the menu under "Option 2". Then look for "System Information" The lamp reset is there
Good luck
PS: Change/clean the filters too!
Posted on Aug 15, 2010
  • 35 Answers
SOURCE: our projector (Panasonic PT AE900U) is still
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Posted on Oct 27, 2010
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Televison & Video
How to replace bulb on panasonic pt-47wxd63g ?
This model has three picture tubes and no bulbs or lamps.
you have provided a model number and if you tell me what set is doing or not doing I may be able to help.
Dec 23, 2012 | Televison & Video
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
What is the correct bulb for the PT-61LCZ7? How do I replace the bulb?
the correct bulb for your model is LFS4000PA1. Go to the Panasonics website and download your owners manual. It will tell you how to replace your lamp
May 28, 2010 | Panasonic PT-61LCZ70 Television
How to change the bulb in my panasonic 52 inch model # pt-52lcx66 tv
I can help you change your bulb and reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
  1. Installation instructions for the TYLA1001 bulb are here.
  2. Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Aug 22, 2009 | Panasonic PT-52LCX66 Projection Television
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Need bulb
Post your model number and I will post a link where you can get one at.
Apr 26, 2008 | Televison & Video
PT-53wx53 replacement bulb
Your model doesnt have a bulb. The PT 53WX53 is a progressive scan CRT projection TV. You have 3 CRT Tubes, Red, Green And Blue. Hope this helps. If you need more info let me know.
Jan 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Plastic housing
moz-screenshot-1.jpgTry this link and download the manual. See page 81.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Nov 16, 2007 | Panasonic PT-50LC14 50" Rear Projection...
114 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
