Question about FoodSaver Advanced Design V2840 Vacuum Sealer Kit
No power when you close catch - FoodSaver Advanced Design V2840 Vacuum Sealer Kit
Dyson 25 canister release spring
It should be placed behind the catch (button). If the button retainers are not broken off, just place it under the catch and snap it back into place.
Dyson Helpline:
1-866-MY-DYSON
or
questions@dyson.com
Jun 13, 2016 | Dyson Dc 25 Animal
Where do I find a hose diagram for my carpet cleaner
Check your User Guide. For a ProHeat it will page 4 or on the assembly directions page 6. The hose wraps around the big loops close to the handle and the electric wire wraps around the loops with the catch that turns. Hope that helps.
Jan 17, 2016 | Bissell 8910 ProHeat Clear View Upright...
I cant get my Dyson canister to reattach correctly.
Hi Gayla, it's Jack at Dyson.
I'm sorry to hear you're having difficulty replacing your DC28's clear bin and cyclone. They should lift away from the machine when you push the red release catch, and should reattach in the same way without any issues.
From what you've described it sounds as if something is out of place. You may want to remove and replace the washable HEPA post-filter as shown in the video below - if the clear post-filter cover isn't fitted correctly this could prevent the bin from sitting correctly on the vacuum. Make sure all the black rubber seals are in position, and that the bin base is closed all the way around. It's also a good idea to check the red release catch for any damage.
If you continue to have difficulties you're welcome to get in touch for some additional assistance. You can reach us by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Feb 26, 2015 | Dyson DC28 Animal Vacuum
How do you refit the lift filter release catch spring which has been dislodged?
I will see if i can take a photo of this when i get 5 minutes and add here.
Contact Dyson regarding the fault.
There is a 5 year warranty on parts their customer service is amazing . They may send you a part to fit if faulty .
Sep 15, 2014 | Dyson DC15 The Ball Upright Vacuum...
Power cord warms up
They do get warm and that is normal. You will see it melt before it catches fire. The amount of electricty that is being used is close to the amount the cord can take.
Feb 15, 2014 | Hoover Vacuums
Hdc11 i cannot close telescopic wandow do i close telescopic wand
I'm sorry to hear you're having difficulty collapsing your DC11's telescopic wand. It should retract in one smooth action when you hold down the catch - if it seems to be jammed, it's probably best if you get in touch with us directly. One of our experts will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 23, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Fitting internal bin catch on dco7
Yea I can definitely help you. On the tope of the cyclone there are three screws that will allow you to take off the top off the cyclone. You should see a long black rod going down the middle of the cylcone. It is difficult and you may have to detach it from the top i cant remember as usually i just replace the whole thing and only done that 3 times. You take a flash light and you can see where the rod goes in and just push it down and it should pop open. ill check back on monday to see if you replied or need more help.
Dec 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
DC 18
You can take it to Best Buy for repairs or a local Shop. Make sure to bring you receipt.
Sep 28, 2008 | Dyson DC18 all floors Bagless Upright...
FoodSaver Advanced Design V2840 Vacuum Sealer Kit Logo
14 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
ray gallant
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
