Question about Dymo LabelWriter 400 Thermal Printer
Can't change paper available in dymo 400 properties
Installed Windows 7 and Dymo 400 Turbo won't print after downloading latest software and drivers. Have been through all fixes I can find without success. One unresolved error (?) that I can't fix is that I can select installed label in Printing Preferences (30321 Large Address), but in Printer Properties General Tab, the "Paper available" window shows "30252 Address" and there is no access anywhere to change that - dropdown is greyed out. Any attempt to print, the printer lurches in to life, prints 2 mm and then stops and displays "printer error". Print Test Page does not work but printer function works OK.
4 Suggested Answers
SOURCE: DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
I unplugged the printer and plugged it back in and it started working and has been working since.
Posted on Mar 24, 2008
Unplug the printer and wait 30 seconds then plug it back in. Mine printed everything that was in the queque.
Posted on Oct 16, 2008
JackHeath
  • 1049 Answers
SOURCE: Dymo Labelwriter 450 Turbo won't print on Windows
Uninstall the driver, remove any trace of the install from the system (as much as is possible). Whent his gets messed up it's really hard to get working on that machine again under XP. Aquire the printer through add printer and detect not the software on the CD, install the driver using the inf file on the Cd. Now reinstall the printer software using USB or serial as an option, when prompted select custom install and no driver. If you have it setup on another machine this also works, but acquire the printer through network neighborhood instead of using add/remove programs.
Posted on Apr 07, 2010
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 400 laser turbo prints the label then multiple labels after that
This is due to the print template you have chosen.
control panel > printers > right click dymo print icon > properties > press "printing prefrences" in General tab > click "Advanced" button in layout tab
Here you can choose the paper size. The dymo "shipping label" (30573) sold in most office stores is template number is "30323 Shipping".
Also these templates choices are available in the software you are using to print the labels under file -> print setup or whatever your software calls it..maybe "print setup"
Hope this helps.
Jan 21, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
My Dymo LabelWriter 400 Turbo stops printing after it has printe
Did you change the number of copies to print prior to printing?
Jan 16, 2018 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo Twin Turbo install on network
You need to download the Dymo software 7.8 from Dymo. Start with the system that has the printer plugged into it. Install the software and make sure it works (prints labels) Now go to Printers and Faxes and find your printer. Right click and choose properties. Then the Sharing tab. Choose a share name that is simple. The printer will now be know to other installs as \\computername\sharename
Go to the next computer and install the software - CHOOSE NETWORK when you get the part about connection. Either enter your host computer info from above or BROWSE to it via Windows Networking. All should be fine now.
Dec 08, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Consistantly Intermittent Connection Problems
If you've tried installing the latest drivers and the problem persists it sounds like you have a lemon. The printers have a 2 yr warranty, so I would contact the retailer you purchased from and replace the printer. If your labels are jamming. Try the compatible File Labels available at LabelValue.com. They have both the Dymo 30327 and Dymo 30277 labels in a compatible version.
Feb 29, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo Labelwriter - Compatible Labels
Nina try www.labelvalue.com for Dymo labels and Dymo compatible labels. The shipping is also free.
Feb 15, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
1,466 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
