Question about Brother GX-6750 Typewriter
New tape, not leaving a mark
Types, but doesn't leave a mark, new tape, installed properly.
How do you remove the factory spoiler attached with 3m tape
The product "Goo be gone" probably will leave marks.
Apr 25, 2014 | 2005 BMW 318i
Tip
Surface Burner Replacement on Electric Smooth Top Range
Steps necessary to replace one of the surface elements on a smooth top electric range.
Before you begin:
1. UNPLUG the range before servicing.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
on Apr 05, 2010 | Kitchen Ranges
My camera was dunked in a swimming pool. I tried replacing the battery and the camera still does not work. Is there any where to get repairs done on samsung cameras or should I just replace the camera?...
Doesn't sound very promising, but there may be some hope.
Remove the card and the battery and leave the cover open.
Don't laugh, this procedure worked on my cellphone.
Wrap it loosely in a piece of T-shirt type cloth, and put it in a little box and cover it with rice.
Rice is an excellent moisture absorber.
I'd leave it there for a week or so.
If that doesn't work, might as well get a new camera.
... the submersible type ...
Jun 24, 2011 | Samsung SL102 Digital Camera
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
How to top up fluid in transmission
Drive the car for about 20 minutes. When you stop and check the fluid, leave the car on level ground and the engine on, in park and with the parking brake on. Check the fluid - it should feel pretty warm. Confirm that you have the proper type - the dipstick may say what type to use and the owner's manual definitely will. The fluid should be added to the tube where the dipstick came out of in small amounts. Add a few ounces at a time if any is needed at all to get it to the upper mark. Don't overfill . If it's only a small amount low, leave it alone.
Sep 21, 2010 | Ford Futura Cars & Trucks
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Print wheel is skipping and sometimes it leaves little marks instead of letters
REMOVE THE PRINTWHEEL, LOOK FOR BENT OR BROKEN SPOKES, ALSO BE SURE THAT THE CORRECTION TAPE IS THE DRY TYPE, THE STICK ONES WILL GIVE YOU FITS.
DickyO
Jan 07, 2010 | Swintec Office Equipment & Supplies
Install a new cartridge does make a mark on paper it tries to print but don't. tried to clean cartridge still doesnt leave any mark on paper
Your probably got a bad print head in this inkjet your looking around $15-30 for replacment of the print head. Since your tryed cleaning and allignment this what is left in the conclusion.
Thanks and please leave feedback
Dec 13, 2009 | Compaq Inkjet IJ600 Printer
Installed new ribbon. appears correctly installed.
There is probably a fold in the ribbon usually the bottom, reinstall it and be vsure it is flat between the guides.
DickyO
Oct 02, 2009 | Lexmark Wheelwriter 15 Series II...
I have a belkin wireless router how do i set the password on it i am using vista
Hi v_venom,
What you need to do is open your internet browser and in the address line type in 192.168.2.1. And I'm assuming you've got the router hooked up properly. Once you type that address a user name and password dialog box will appear. Leave the password blank and click "Login" On the right side menu options, click on System Settings, and it will allow you to enter a new password for the modem.
Good Luck,
Mark
P.S. Please don't forget to leave a rating.
Feb 18, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Brother GX-6750 Typewriter Logo
37 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
