Question about Jandy Laars Hi E2r Heater 350k Btu Natural Gas, Residential
Jandy hi e2 heater calls for heat - Jandy Laars Hi E2r Heater 350k Btu Natural Gas, Residential
  • David Spradling
    David Spradling Dec 01, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? does the fan come on and does the ignitor glow if not check safety circuit there is a resettable fusible link in front up near top
4 Suggested Answers
  • 246 Answers
SOURCE: gas heater and heat pump chiller control problem
NO. BUT YOU CAN CONTROL WHAT EQUIPMENT TO COME ON BY INSTALLING A RELAY FOR EACH ONE THEN ASSIGN A AXUILIAR BOTTOM IF ANY LEFT
Posted on Nov 18, 2009
  • 246 Answers
SOURCE: I have a Jandy Hi-E2 heater, when I try to turn it
THE IGNITION LOCKS OUT BECAUSE THE HEATER DID NOT FIRE MUST BE TRUOBLE SHOOT BY A PROFESSIONAL SINCE VERY HARD FOR ME TO TELL YOU WHAT IS MAKING THE HEATER NOT TO WORK
Posted on Dec 30, 2009
I am a chief maintance at a courtyard marriott and i have the same problem my ignition board blinks 3 times and says ignition lock out and usually it has something to do with the flow so may want to check a flow issue
Posted on Aug 24, 2012
Jandy HI-E2 350K pool heater vent limit switch is resetting, flow is fast and good, but water temp is getting over 140 and kicking vent limit switch out
the vent switch is for the exhaust. the 135 high limit should be opening if the water temp is getting to 140 degrees.. 1 safety will kill the entire circuit since they are all wired in series
Oct 10, 2013 | Zodiac Jandy Hi-E2 350K BTU Residential...
What is the difference between hi e2 fresh and salt water heaters?
yes has a nickel heat exchange rather than copper you still need to make sure gas pressure is adequate and proper chemistry
May 26, 2013 | Jandy Laars Hi E2r Heater 350k Btu Natural...
Hi e2 jandy heater
check pressure switch and copper tube to it
Jun 08, 2012 | Jandy Laars Hi - E2 350,000 Btu Heater
I have a leaking Heat Exchanger in my Jandy Hi-E2 Pool Heater. Do you have instructions for replacing it?
major overhaul call a professional if not correctly done waste of money or buy a new heater
Jun 27, 2011 | Jandy Laars Hi - E2 350,000 Btu Heater
Hi-E2 350 heater trips thermal switch on exhaust collector after 10-15 minutes of run time. Went through the manual tested all gas and air pressures with digital differential manometer, adjusted to within...
Check the condition of the heat exchanger. If it is heavily sooted from prior to adjusting gas pressure it will not vent properly. Check for downdrafting or blockage in the flue pipe if the heat exchanger is not sooted.
If the heat exchanger is sooted a good steam cleaning or even a trip to a car wash should remove enough soot for it to return to operating normally.
Dec 15, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Laars HI EZR heater does not come on
Hi. I work on Laars HI-E2 heaters at the hotels and there are 3 possible problem. The igniter, ignition control module or "not enough air for good hot combustion" are the main sources. I can go into details about my experiences. I suggest it is best to contact a service company to look at the problem.
Apr 25, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Heater will not heat
If you dont smell any gas make sure that all gas valves between the heater and the main gas meter are open, and the gas valve in the heater is in the on position. Try cleaning out the nozzles that the gas comes out of. Sometimes they can build up with cobwebs.
Apr 08, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Jandy Laars Hi E2r Heater 350k Btu Natural Gas, Residential Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
