Question about LG DLG3788W Gas Dryer
LG gas dryer is not hot - LG DLG3788W Gas Dryer
Gas dryer lg trom dlg5988B does not get hot.
If it has been under water you need to have it professionally serviced. The gas igniter is electronic and there are safety circuits to prevent explosions and getting gassed..
Nov 26, 2017 | LG Dryers
We have an LG dryer DLG5966 that runs but will not dry the clothes. It doesn't get hot.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 15, 2011 | LG Dryers
Lg dryer not getting hot
can be many problems; gas valve, igniter, thermostats. you will need a qualified tech to check out. of course, check the exhaust hose and damper door for cleanliness.
Aug 16, 2010 | LG DLG5932W Gas Dryer
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
Dryer Starts Spin but No Hot Air DLG5932W
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 31, 2010 | LG DLG5932S Gas Dryer
LG dryer doesnt get hot
Hi, If you have a gas dryer2_bing.gif.
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 01, 2010 | LG DLE2532W Electric Dryer
LG dryer DLG0452W not getting hot. (gas not turning on)
reset circuit breaker outside burner chamber, and cleaned out the unit.
Feb 24, 2010 | LG DLG0452W Gas Dryer
LG GAS DRYER NOT LIGHTING THE SECOND TIME AFTER COLD START. IGNITOR COMES ON: SENSOR SEES IT IS HOT ENOUGH AND GAS VALVE OPENS. FLAME COMES ON THEN GOES OFF WHEN TEMP IS REACHED BUT WHEN DEMAND FOR THE...
If your vent is clear (strong flow of air at vent outlet outside) then you have a bad gas valve. I have seen this a few times on LG gas dryers. You really only need one of the coils on the gas valve, but they are not available individually. You have to get the entire valve.
Oct 28, 2008 | LG Dryers
LG DRYER DLG2532W GAS
Dryer doesn't get hot. Replaced all the sensors and still it doesn't get hot. Doesn't get hot in any mode. All vents are clear. I'm thinking that maybe there may not gas getting ignited, but I know nothing about gas stuff and am not sure if thats the problem. Any ideas of what I should be looking at next?
May 15, 2008 | LG DLG2532 Gas Dryer
LG DLG3788W Gas Dryer Logo
55 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
