Question about Turbo Air M3R47-2 M3 Refrigerator
M3 turbo air not cooling - Turbo Air M3R47-2 M3 Refrigerator
Turbo air m#TSF-72SD will not hold below freezing. Cleaned coil an temp dropped to 29 but no further...
If everything else is in proper working order, either a refrigerant level issue or and expansion device issue. If system constantly runs the previous, if not, possible temperature control. Look for system cycling or not cycling.
Jan 10, 2018 | Turbo Air Freezers
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Turbo air frz goes into defrost compressor continous to run. Does not stop during defrot
Hi, Please set your thermostat a bit warm and observe the compressor. Also check your freezer for leaking.
Nov 06, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Looking at new freezer, what is the difference between Turbo air TSF-23sdr and TSF-23nm? product specs would not download. thks
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
Sep 22, 2010 | Turbo Air 23 cu. ft. / 651 liter...
My refrigerator is running but not cooling compressor is hot
Check the consenser and see if it is clean.
Be sure the compressor is running and not just the condenser fan.
Jul 22, 2010 | Turbo Air 12 cu. ft. / 340 liter Chest...
Where can I order extra shelves and support clips for GST 40GF
Call Rick at Restaurant Parts and More in Ohio. Give him the model and serial numbers and he can match what you need. FYI, most Turbo Air freezers are also Masterbilt. Turbo Air does the private lable thing for Master bilt.
Hope this helps.
Mar 11, 2010 | Turbo Air Freezer Green World by Bottom...
M3 Turboair Refrigerator does not cool
http://www.turboairinc.com/TB-Service/Service.html#SANDWICH
Try this web site. It has you M3 listed with manual but needs exacting model number to get right one.
good Luck - Hope this works for you. If not, let me know.
Jun 27, 2009 | Freezers
Turbo Air M3R47-2 M3 Refrigerator Logo
452 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
marlin siecinski
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
