Question about HP Office Equipment & Supplies
AFTER REINSTALLATION HP SJ200 (L2734A) A MESSAGE SAYS: Windows is searching for hpqkygrp.exe
I have tried to uninstall and reinstall it with the cd.no awail.
5 Suggested Answers
SOURCE: HP Director malfunction
Error:CLR 80004005 For XP only
Fix.
Right click on the programs exe. File (ex. Quick quote Icon) go to properties, click on compatibility. Uncheck “ Run this program in compatibility mode for” Click apply, and then OK.
Posted on Mar 21, 2008
SOURCE: HP PhotoSmart C4440, All in
I did not find a "solution" to the HP CUE - Scanning Flow Component problem. However, I did find a work around the problem. I use my graphics editing program to Import/ Acquire/ From Twain and this will allow me to scan from the printer to my graphics program. I can save the image from there.
Better than not being able to scan to my pc at all ...
Posted on Sep 27, 2008
  • 103 Answers
SOURCE: My scanner has failed. Below is the info I have
I suggest you reset the all in one device.After that try copiing with the printer stand alone.
Posted on May 06, 2009
michael_grey
  • 365 Answers
SOURCE: HP 4570C flatbed scanner. Windows XP. USB
Go to the control panel and look under cameras and scanners.Then look under events.You should be able to figure it out from there.
Posted on Jul 22, 2009
Maybe you can help with this... I could only get online by doing a system restore. So I tried to fix the problem by uninstalling service pack 3 and installing the latest version. I did this successfully...
You will have to do a complete factory reinstall at this point. Hopefully you have your data saved so it won't be lost. The disk you have should work, but you'll have to boot from the CD drive. Insert the manufacturer's disk in your CD drive and then restart the computer. Hopefully it will automatically start the reinstallation. If it does, just follow the prompts to reinstall the operating system. If not, let me know and I'll talk you through how to tell your computer to boot from the CD drive first.
Apr 03, 2011 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Usb error
To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Jul 23, 2010 | HP LaserJet P2015 Printer
Get message unable to start driver hppapm10.exe. How can it be fixed ?
try to uninstall and reinstall all the compaq drivers... may be caused due to the driver corrupt or hardware prob... let me know if the prob continues even after reinstallation of all drivers.
Jul 13, 2010 | Compaq Computers & Internet
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
Sep 07, 2009 | Office Equipment & Supplies
Cannot uninstall or install HP scanjet G2410
I tried all the "decent" uninstall solutions like running HP's Level 1-4 Uninstall batch files. HP's installation software still insisted that parts were already installed. Then, with the scanner connected, the installation software got into competition with Windows also trying to install the driver. The reinstallation was no good. Solution Center wouldn't even start, preposterously announcing that it couldn't find the scanner!
When you have a reliable clone of your c:\ drive you can try daring solutions. Such as this:
1. Search the c:\ drive for files and folder with "Hewlett" or "HP" in their names. Kill them all.
2. Search the registry for keys with "Hewlett" visible or buried. Kill them all.
After 1 & 2, reinstallation worked smoothly. And my computer still works! The only evidence of the violence is an undeletable file 3963d.rbf now in c:\Config.Msi. I will report back if serious computer problems arise.
The point is that manual uninstall is possible and none of the elements are in hidden places. Someone else can determine whether both file and key deletions are necessary and exactly which ones.
Apr 08, 2009 | HP Scanjet 4470c Flatbed Scanner
Can't scan on HP Photosmart C4380 even tho printing works fine
Try scanning without HP imaging software
HP Photosmart C4380 Direct Scan button doesnt function in VISTA
Use the built-in feature of the Windows operating system, called Windows Image Acquisition (WIA), instead of the HP software to scan. Follow these steps to perform a WIA scan.
  1. Make sure that the product is on and that the cable is correctly connected.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon representing the product, and then review the following information for further instructions:
  5. Double-click the icon to start the Scanner and Camera Wizard . Follow the on-screen instructions to scan images or documents to the computer
  6. If the WIA scan was successful , use the Scanner and Camera Wizard to scan instead of the HP software. To use the HP software, continue to the next step to continue troubleshooting. However, it is not necessary to do so.
  7. If the WIA scan was unsuccessful , continue to the next solution.
  8. Fully uninstall and reinstall the HP software Follow these steps to completely uninstall and then reinstall the HP software. Step one: Uninstall the software Use one of the following methods to uninstall the software. Method one: Uninstall the software using the product CD If the product software CD is available, follow these steps to uninstall the software. Otherwise, skip to the next method.
    1. Insert the software CD into the CD-ROM drive on the computer.
    2. If the Welcome installation screen appears, click Exit to close it.
    3. On the Windows task bar, click Start , and then click Run (c01463550.gif ). The Run dialog box appears. Figure 4: The Run dialog box c01463551.gif
    4. Click Browse . The Browse window appears.
    5. Navigate to the CD-ROM drive that the software CD is in, and then double-click the drive.
    6. From the list of folders and files on the CD, double-click the Util folder.
    7. From the list of folders and files inside the Util folder, double-click the CCC folder.
    8. From the list of folders and files inside the CCC folder, double-click the Uninstall_L3.bat file or Uninstall_L3_64.bat if a 64-bit operating system is installed on the computer. The Browse dialog box closes, and the path to the Uninstall _L3.bat file appears in the Run dialog box. Figure 5: Uninstall file path in the Run dialog box c01463552.gif
    9. Click OK . The software uninstaller opens in a command prompt window.
    10. Press Enter to begin the uninstall.
    Method two: Download and uninstall the software If the software CD is not available, follow these steps to download the software and then uninstall it.
    1. Click here to go to the Software & Driver download page on the HP Web site .
    2. Type the product number in the search field, and then click Submit (c01425574.gif ).
    3. If necessary, click the link for the product model number.
    4. Click the correct operating system.
    5. In the Driver section, click HP Full Feature software/driver , and then click Download only .
    6. When the File Download - Security Warning dialog box appears, click Save .
    7. Save the file in a location that is easy to remember.
    8. When the file finishes downloading, double-click the file to extract it.
    9. Click Exit on the Welcome installation screen.
    10. On the Windows task bar, click Start , and then click Search (c01463553.gif ). The Search Results window appears.
    11. In the Search Results window, click All files and folders .
    12. Click More advanced options , and then select Search hidden files and folders .
    13. In the All or part of the file name: box, type Uninstall_L3 , and then click Search . When the search is complete, the file appears in the Search Results window.
    14. Double-click the Uninstall_L3 file, and then follow the on-screen instructions to complete the uninstall.
Oct 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP PhotoSmart C4440, All in one will not scan image to computer. I receive an error message stating: HP CUE - Scanning Flow Component has encountered a problem and needs to close. Details from error...
Sep 26, 2008 | Office Equipment & Supplies
Uninstall Problem
If you are installing the software using Windows and the software was not successfully installed or the uninstaller could not be found, run the Scrubber Utility to perform a clean driver uninstallation Use the Scrubber Utility Use the following steps to run the Scrubber Utility.
  1. Disconnect the printer from the computer.
  2. Restart the computer.
  3. Insert the Starter CD into the CD drive. If the CD menu displays, close the CD menu.
  4. Locate the Utils\Scrubber folder on the Starter CD.
    • For Windows 98 and Windows Me, use the scrub9x.exe file located in the Utils\Scrubber\Win9x_Me folder.
    • For Windows 2000 and later, use the scrub2k.exe file located in the Utils\Scrubber\Win2k_XP folder.
  5. Double-click the file to run the Scrubber Utility.
  6. The following message will display: This utility will attempt to remove all HP DeskJet 460 Series devices from your system. It is recommended that you disconnect the device and restart before continuing. Do you want to continue without rebooting?
  7. Click Yes . A message stating Successfully removed the devices(s)! This system is ready for installation displays after the scrubber utility finishes running.
  8. Click OK .
  9. Restart your computer, and then reinstall the printer software
Apr 27, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Fix.
Mar 20, 2008 | Office Equipment & Supplies
88 people viewed this question
Seeker5211
Seeker5211
