Question about Sewing Machines
I need a belt for an old Necchi Lock serger NL-3
I can tell the belt is slipping and won't run the machine. Hope someone can tell me where to get a belt
  • 6 Answers
SOURCE: need parts for old Necchi Lydia 3 Sewing Machine
GO 2 STAPLES
Posted on Jun 16, 2008
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
  • 8 Answers
SOURCE: Need belt for necchi supernova automatica sewing
You can also use a Eureka vacuum cleaner belt, can't remember the exact model, but the package says it's for most sewing machines. It's not the V belt, but it works on my Super Nova and it's 1.79 for two!
Posted on Oct 11, 2009
SOURCE: Singer Tiny Serger: Motor runs but machine
pull the 4 bottom rubber feet out and remove screws hidden in holes. Lift main body of serger up. you will see the gears. Probably drive gear on motor shaft got hot and slid on motor shaft.
Posted on Dec 12, 2009
  • 108 Answers
SOURCE: Operating manual for Mini Lock FR 850 Serger
try at www.ifixmachines.com
Posted on Feb 15, 2010
Tension problems with my necchi lock NL-4
Without more information as to what is happening with your machine, can only suggest being sure to:
ALWAYS RAISE the presser foot when threading
Start with the tension dial set at the midway point and tweak from there
Nov 05, 2017 | Necchi Sewing Machines
Serge necchi instrution manual 1036
Several are sold on the internet eksampel http://www.monstermarketplace.com/sewing-machine-parts/instruction-manual-necchi-pl1036-sewing-machine Download Free manual for necchi serger http://the-manuals.com/pdf/manual-necchi-serger.html-manual/
Jan 19, 2013 | Necchi Sewing Machines
I was given a Necchi PL1036 and can find no info on it. I do not have manuel, new to sergers...is this machine worth the trouble to use?
if the serger is in good condition then perhaps all that is needed is
a manual, there are no free ones, but here is a link for a manual
http://www.sewingpartsonline.com/instruction-manual-necchi-pl1036-sewing-machine.aspx
I don't know that much about necchi sergers, but I do have 2 necchi
sewing machines one is mechanical and the other is electronic,
they are both good machines, I've never had any trouble out of
either one, and I've had the mechanical one for around 11 years and the
other electronic one for around 9, I make clothes and quilt on them.
Jan 01, 2013 | Sewing Machines
I have a Necchi model 549. I have to hand turn the wheel in order for it to start to stitch then it will run, but as soon as I stop it needs to be hand turned again. it will not sew upholstery or heavy...
I have the same machine and have had a similar problem. My belt was just old though. You need a new belt. And once installed it must be adjusted properly for everything to work correctly. I changed and adjusted mine myself. Although Necchi parts are not available from the company any more, there are several places online that carry belts and a few other items. One is sewingpartsonline.com. The belt shows up under Necchi 541, but it lists compatibility with our machines (549) on the order page. The size belt is 12 5/8"-- with teeth (lug type). While the belt is being changed the shaft that holds the wheel needs to be cleaned and oiled. Also clean up any excess oil in the area with a sewing machine safe cleaning fluid. Clean the plastic wheel with a little dish detergent and water on a paper towel. Oil should not be put, or remain, on any plastic parts in your machine. Not many people want to fix these machines anymore, but I love mine and will probably keep it as long as I can keep it running. Hope you see this post and get your machine running again. Win
Jan 15, 2012 | Necchi Sewing Machines
Need instruction manual for Necchi Proo-Lock serger, do you know where I can purchase one or perhaps download from internet?
Wasn't able to locate a free download but here's one on Sewforless.com for under $15.00
http://www.sew4less.com/product/4207/Necchi_6002_Instruction_Manual
Jul 16, 2010 | Necchi 6002 Sewing Machine
I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
Jul 07, 2009 | Necchi 6015 Mechanical Sewing Machine
Drive belt for old machine
You can get Necchi sewing machine belts here, all you have to do is measure your old belt and find that size
<a href="http://sewingpartsonline.com/sewing-machine-belts.aspx">Sewing Machine Belts</a>
Dec 15, 2008 | Necchi Sewing Machines
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
