Question about Epson Stylus Pro 3880 Inkjet Large Format Printer - 17in. - Color
Printer is way off centre
We recently moved the printer to have our house painted. I went to print my first image since then and it is printing WAY out of line. It is only printing the bottom 1/4 of the picture on the bottom part of the paper - as if the entire printer has been shifted way too far over. I did the printer head alignment but that has not seemed to work. Would love any help you can give me. Thank you so much.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
There should be a printer calibration option in the printers utilities. It will help if your post the model.
Posted on Aug 05, 2017
  • 691 Answers
SOURCE: Clogged printer heads
If you soak the head, you may as well bun the printer. So many people have wrecked their machines doing exactly what you are doing. If you force any liquid through the print head, you stand a really chance of blowing the piezo actuator and rendering the machine useless.
I assume you have been using non genuine ink cartridges, as these are usually the cause of most similar problems. Ever wonder why Epson do not make cleaning cartridges but all the compatible cartridge makers do? Running cleaning cycles with compatible carts can make the situation worse.
Take a look at my previous post about under head cleaning. You can find an example HERE. Get a set of genuine carts and put them in once you have completed the under head cleaning. In most cases this type of cleaning is sufficient to get most printer running again. If your nozzles are seriously clogged you may want to let the pads soak over night.
Avoid using a neat ammonia, the print head will not appreciate such a strong solution. An ammonia based cleaning solution would be more suitable.
Also bear in mind that if the pipes to the waste pads from the pump cap are clogged you may also loose some print quality and running cleaning cycles will have no affect as they rely on vacuum from the pump cap.
If you are going to use compatible carts, put a genuine set of carts in every second or third set. These will help clean out the solidified muck left by compatibles.
Try this and let us know how you fair.
Posted on Oct 16, 2007
  • 328 Answers
SOURCE: Print Head Alignment
Get the driver here:
Posted on Oct 29, 2007
  • 1879 Answers
SOURCE: epson rx 500 print problem
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link .
Posted on Jan 26, 2008
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Posted on Mar 28, 2008
  • 33 Answers
SOURCE: Epson Stylus Pro 4800 Never Before Seen Banding Problem
Is there any debris under the printhead nozzle plate?
Posted on Jul 01, 2008
How to send fax from paint
Faxes are sent by the scanner. Print out the image from Paint then place the print in the scanner then fax it.
Dec 14, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
go to your image and right click on it, click on "preview" once the preview screen is open look at the row of options (I"m assuming windows 7 op system here, but you can do this with XP too). anyway.look for the option "open" along the top, a row of choices will appears, choose "Paint" when paint opens you can see on the left an option to rotate, or flip your image, choose flip horizontal and you will now have the reverse image, save it to someplace you can find it and then it will print as you wish (reversed).
Mar 17, 2011 | HP LaserJet 1020 Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
Is there a way to print 'mirror image' for an iron-on for a Deskjet 5550? I need to flip the entire document (one page) so it prints backwards.
You simply need to create the image in MS Paint program etc, all you have to do is "Invert" the color. get the black & white image into paint and invert the colors.
Feb 23, 2010 | HP Photosmart C7280 Laser Printer
How to print page shown on my monitor with printing a whole book
Use the Alt & Print Screen (PrntScrn) keys simultaneously to capture the screen.
Go to another program such as Paint, Word, anything you can Paste the captured image into.
From there, simply print the image.
Sep 20, 2009 | Lexmark X2500 All-In-One Printer
Epson Stylus Photo 870 only prints black and white
WHen your p;;rinter name comes up, check the printing p;references. You have "P:rint colors as black & white" checked. Un check it. It is in the printer dialog box, not PSP.
Sep 15, 2009 | Epson Stylus Photo 870 InkJet Printer
I have a C3530 MFP and it won't print because it says check toner cartridge black. Toner Sensor Error
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Jul 30, 2009 | OKI C3530N Color MFP Printer
How do i reverse the letters for print on tee shirt
try using windows paint, put the image there and go to image- flip/rotate then tic flip horizintal. bingo then save the image and print in the photo editor of choice.
Jul 26, 2009 | Canon Pixma MP480 All-In-One InkJet...
Hi I am Vortash if you want a mirror image of anything you print all you have to do is reverse it in the picture or the writings you are printing .. most good graphic/ paint programs will allow you to do this Paint shop pro to name but just one and Coral ?
So If you want the picture on your t-shirt the right way round after transfer just select mirror image before you start your print run .. Regards Vortash
May 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Stylus Pro 3880 Inkjet Large Format Printer - 17in. - Color Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
