Question about Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
My paper white will not come on when swiped - Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
Kindle paper white won't move from the first page that shows up.
Try swiping your finger across the middle of the screen from right to left. This action turns the page forward. Swiping your finger across the middle of the page from left to right turns the pages backwards. I don't think the icon on the bottom is for page turning.
May 04, 2015 | Amazon Kindle Paperwhite
Cant connect to wifi because bluetooh is stuck running a prograhm
You can turn off BlueTooth by either going to Settings-->Bluetooth, or touching the BlueTooth icon in the Control Center (swipe bottom to center to bring up the Control Center).
Test your WiFi. If it doesn't work, double-click the Home button, locate the program BlueTooth is running, and swipe it to the top of the screen.
Test WiFi again. If it doesn't work, power down; wait 5 minutes; and power up your phone (if you don't see the white Apple icon when powering up, you did not power down properly).
Feb 15, 2015 | Apple Iphone 4s I Phone 4 S Factory...
My galaxy is stuck on the swipe page it wont swipe what do i do
If you have forgotten your swipe password you will have to do a hard reset. DOING THIS WILL CAUSE YOU COMPLETE DATA LOSS AND YOU WILL HAVE TO START OVER UNLESS YOU HAVE PREVIOUSLY SYNCHED YOUR PHONE TO GOOGLE OR HAVE BACK UP YOUR PHONE WITH SOME OTHER BACK UP APPLICATION. To reset PHONE TURN IN OFF, AND WHEN TURNING IN BACK ON HOLD THE POWER BUTTON AND THE VOLUME BUTTON DOWN UNTIL YOU SEE THE GREEN ANDROID MAN THAT LOOKS LIKE HE HAS A TOOL CHAIN BELT ROTATING AROUND HIS ABDOMEN
Jul 28, 2014 | Samsung Galaxy S3 III I9305 LTE Unlocked...
Swipe wont open phone
It seems that the digitizer is not working properly, if you bought new i suggest you return it.
Apr 18, 2014 | Samsung SPH-L720 Galaxy S4 16GB Sprint...
Use finger swipe
re install it ...check the settings
Jun 02, 2013 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
How do you change the screen on a samsung conquer
Hi
Press menu.
Swipe side to side until you arrive to the wallpaper option.
Tap on wallpaper.
Select the desired wall paper option and tap on it.
Scroll the desired wall paper and tap on set wallpaper.
Good luck
Feb 23, 2012 | Samsung Cell Phones
Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2 Logo
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
