Question about Lincoln Automotive Pneumatic Grease Gun Model 1163
Housing cracked at hose connection - Lincoln Automotive Pneumatic Grease Gun Model 1163
I have a leak on a hose that connects to thermostat housing.
Radiator top hose or return hose, most likely cracked when you removed it to replace the housing. Undo the clamp at both ends of hose remove and replace.
Apr 19, 2015 | Cars & Trucks
Leaking water on the bottom of the washer while washing. Could you please tell me what`is wrong with my washer.
Water leakage
1. Inlet hose loosely connected to valve---tighten hose connection
2. Drain hoses not tight on pump----tighten hose clamps
3. Broken hose---replace hose
4. Leaky gasket---replace gasket
5. Cracked housing---replace part
Sep 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from underneath my washing machine. how do I fix it? the hose is connected properly, too
Water leakage
Sep 22, 2011 | GE Washing Machines
There is a leak at the water outlet housing wherethe overflow tubing connects to it. There is no gasket or o ring to solve this.. how do you fix it?
check the radiator hose going to thermostat housing.it could be leaking.if hose okay.thermostat seal more likely leaking, meaning you have to replace the thermostat with seal.if thermostat with new seal still leaking.thermostat housing has a small crack in it.need replacing.
Apr 12, 2011 | 1999 Oldsmobile Alero
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
Leaking thermostat Housing (Seepage on the top side)
If it's leaking at the hose connection make sure the clamp is properly tightened. Remove the hose, clean the area well and retighten. If it's leaking at the gasket you'll need to reove the housing, completely strip the old gasket and apply a new one. Be sure the area is completely clean before putting the new one in place.
Nov 03, 2009 | 2001 Chrysler Sebring
Maytag wahing machine leaks from bottom
HI. i would advise to inspect all drainage hoses that are connected to the water pump inside the unit. One of the main causes of this type of leak will be a lose hose or, cracked pump housing. Check all hoses.
**(Note- The other areas will be the actual inlet valve assembly. Check the entire assembly for cracks and lose hose connections as well. If you find any fouled hoses, replace the affected hose asap.)
I would also inspect the outer tube for cracks and corrosion. this will happen over time, causing leaks of this nature. This is uncommon but, it can occur. Lastly, check the tube seal and bearings for trama. replace if nessecery...
Aug 12, 2009 | Maytag PAV2300 Top Load Washer
What I think is the heater hose cconnection to
PUMP MUST BE REPLACED if ANY Part of it is BROKE, as this can Lead to MORE cracks, and Ending in Catistrofic Failure.
Aug 01, 2009 | 1999 Plymouth Voyager
Lower radiator hose leak at water pump housing
water pump housing is cracked ,replace the water pump
Apr 11, 2009 | 2002 Chevrolet Suburban 2500
Lincoln Automotive Pneumatic Grease Gun Model 1163 Logo
23 people viewed this question
Top Lincoln Air Tools & Compressors Experts
Steve P
Steve P
Bill Boyd
Are you a Lincoln Air Tool and Compressor Expert? Answer questions, earn points and help others
