Question about Cycling
What is fuel oil ratio when run in 49cc quadard
2 Suggested Answers
  • 82 Answers
SOURCE: 49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Posted on Apr 29, 2009
Lost the manual and need to know what the fuel and oil mixture ratio is
Hi Barney:
Fuel oil mix ratio for almost all newer 2 cycle motors is 50:1
Cheers
Apr 16, 2016 | Garden
Engine wont start on mini quadard 49cc model atv-2
A lot of guys are having trouble with that. If you have spark. disassemble the carb and clean it. then screw the set screw all the way in and back it out 1 1/4 turns. if you need more you do it in 1/4 turn increments.
Dec 24, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
Mini quadard 49cc model atv-2 pull start problem
a lot of guys are having issues with these machines. Most I believe are due to the carb settings. Turn the set screw all the way in and back it out 1 1/4 turns. Try that. if you need more you do it in 1/4 turn increments
Starting problem with mini quadard 49cc
turn the carb screw all the way in and back it out 1 1/4 turns. This should work. if you need more... do it in 1/4 turn increments.
Dec 24, 2013 | Quad Cycling
I have a 49cc two stroke bike, (pit bike) like new. Starts first time, no problems. But after 10min of riding the bike stalls out. If i leave it for 20min then it will start again. Run for 10min then stall...
Ok, a two stroke engine basicly needs 3 things to run: fuel, compression and ignition.
First, check that the fuelline, fuelfilter, or fueltap is not blocked. If the fuelflow is alright, check that the compression is fine. try kicking the kickstarter a few time: the should be a certain resistance.If the compression is wrong try changing the headgasket. If it is alright, check the ignition. This is done by taking the sparkplug out at placing it on the frame, when you kick the kickstarter a spark should jump from the sparkplug to the frame.
But my guess would be that you have a partly blocked fuelsystem.
Mar 15, 2011 | 2005 Qianjiang QJ100-2
For an 80 cc kawasaki dirt bike what kind of oil mixes with the gas and in what ratio and what kind for engine oil?
I WOULD USE AMSOIL,OR RED LINE SYNTHETIC OIL ( WILL MAKE TOP END LAST ALOT LONGER).. AND THE MIX IS 32:1..... AND FOR ENGINE/TRANY OIL YOU CAN USE BEL-RAY ( BEST IN MY OPINION)
May 20, 2010 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
Battery size (volts) gas to oil mixture
12V battery 40:1 to 50:1 two-stroke ratio, but you shouldn't need to worry about that - it has automatic two-stroke injection.
Jun 28, 2009 | 2004 Vento Gladiator XLS
Runs then cuts out
fix the leak in the head, because you changed the head with a bigger one, you'll have to buy a carburator jet kit and rejet your carb, it'll need a differnet gas/air ratio because of the head kit
Jun 09, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
Apr 24, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
Cycling Logo
35 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
