Question about Zebra S4M Thermal Label Printer
Print speed too slow
I thought these were "high speed", "high quality" printers. I maxed out the speed and darkness settings and it produces an average label at best at an average speed. Is there any different firmware or settings to change to increase performance?
  • 1 more comment
  • pherbold Jun 18, 2009
    No...I'll do that...thanks!
  • pherbold Sep 11, 2009
    I don't think so..I'll do it...thanks!
  • reedm79 May 11, 2010
    After you adjusted the speed to you reclababrate the printer?
  • 32 Answers
There is a print speed in the front panel settings. I believe the max speed is 6" per second. This model is what Zebra considers a mid-range printer, so it is not the high end, which will print 10-12ips.
Posted on Oct 27, 2009
    Champion:
  • 254 Answers
The speed may be sent by software.
Check if the speed instruction isn't in your code?
Posted on Sep 03, 2009
  • pkwc Sep 11, 2009
    To increase the speed, you have to check that graphics are sent in compressed mode and use printer fonts instead of true type fonts
Copying extreemely slow
Things that change printing speed are
-Color vs. Black and White Low 4 PPM High 25 PPM
-Quality DPI Dots per Inch. Usually 100 200 300 DPI
-General speed of the make and Model
-Photo Printers are very slow but produce a clear image.
You can set DPI in setup on the printer
Copiers are just the speed they are
May 04, 2016 | Office Equipment & Supplies
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Hp officejet 4215 prints slow
Change the resolution or quality settings. Slow speed printing usually means its set to high resolution which is not needed for most print jobs.
Aug 04, 2012 | HP OfficeJet 4215 All-In-One InkJet...
I have a Zebra 170Xi II & Zebra 170Xi III plus and the problems is that they print really good at low speed but in high speed it doesn't print almost anything. Already set the darkness of the printer...
if you increse the speed, you need the incrise the darkness, clead the printhead and the white rollar, you can improve the quality if use the correct ribbon and the relation between the ribbon and the paper of the lables are the best. chech with your Media suplier. The problem with the increse speed and the darkness can damage the printhead, and they very expensive.
Nov 01, 2010 | Zebra 170Xi II Thermal Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Aug 28, 2009 | Epson TM-T88III Thermal Printer
No print /No error message
First, you need to make sure the ribbon and labels are loaded correctly. Follow the diagrams on the inside of the door. Once this is done, check the print speed and darkness from the front panel. If you have a high print speed and a low darkness, depending on the media you are using, it may not show the print. Try either slowing the print speed down or raising the darkness.
Aug 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S4M Label Printer
Do you know the print speed that you are using? I would slow it down to about 7 ips and adjust the Darkness until you are happy. Some companies want all this speed and the machine cannot do a good job at high speeds (10 ips). If you are not able to over-ride their speed, call them. It will increase your print quality a great deal.
The print speed is the second setting on the menu. Don't forget to save the settings when you are finished (use "Permanent"). Good luck!
May 29, 2009 | Zebra S4M Thermal Label Printer
Not having good quality print with zebra z4 m
Try slowing down the print speed to 2 ips. Then increase the speed. Usually, this is a problem of exceeding the limits of the printer. The faster you print, the weaker the print. With a ribbon that is matched to the label stock, you will have an optimum speed for best performance.
May 22, 2009 | Zebra Z4M Printer
Cannon Pixma MX310 prints too slow.is there a way to print faster
Go to file menu, select print, and then click properties within the program that you are trying to printer from. There should be speed/quality settings here. It really depends on your printers drivers. But the high the print speed the lower the print quality. Other than that there is no way to have a faster printer without sacrificing quality except to buy a new printer. Laser printers are by far the fastest printers.
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Zebra S4M Thermal Label Printer Logo
265 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
