Question about Roomba Robotic Floor Bagless Vacuum
My Roomba 560 does not automatically dock as advertised either..
My Roomba does not auto dock, nor does it seem to recognize the electronic walls and lighthouse. However, when the Roomba is turned on, the electronic lighthouse/wall units turn on. They are not in line of sight, and all, Roomba and units, are about 30 feet apart and in different rooms. Isn't infrared a line of sight type transmission? If so, how are the remote units becoming aware the Roomba has been turned on? Similar to others who have described this issue, the Roomba seems to be oblivious to the docking station. It will drive all over it at full speed as if the dock isn't there. This feature did work when I first received my Roomba, and rarely it will surprise me and actually dock. The docking procedure is a unique process. You can see the Roomba aligning itself with the transmitter atop the dock, as it slowly and carefully approaches. When contact is made with both metal contacts on the dock, the Roomba issues a proud little tune, and shuts itself down. A great feature when it works, but my impression so far is that it is a gimmick prone to failure. I'd be glad to take that back if a solution can be found for this issue, but as yet that has not occured.
    Problem Solver:
  • 8 Answers
You may not believe this, but the new 500 series lighthouse virtual walls have both infrared and radio frequency communication. How they work and associate with the Roomba is pretty complicated. The best posting I've ever seen about how they work is here:
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=11048
Check out that link to understand how the communication works.
If your Roomba is contained by the virtual walls, then you can assume the IR sensor on your Roomba us good....you should test that though. Then you might have to replace the "home base" which could have a bad IR transponder . New ones can be found for reasonable price at www.RoboticVacParts.com or you could order straight from iRobot for twice the price.
If the Roomba is not contained by the virtual walls, then the IR sensor on the Roomba is likely bad and you'll need to change the bumper on your Roomba. Again ....parts are available through ebay, or www.RoboticVacParts.com. Follow this link if you need it.
http://cgi.ebay.com/NEW-Roomba-500-series-white-bumper-510-530-532_W0QQitemZ270400281066QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef51cd9ea&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Posted on Jun 20, 2009
I have roomba 880 stationed in open w/nothing blocking view (virtual walls, lighthouse, doors, etc) but it will not go back to docking station even when I press docking and its only 6 feet away.
it seems as if the robotic cleaner is having a problem sensing where it is or failing to notice where its charging station is try cleaning any optical/IR sensors and it maybe able to see once again where its charging dock is
Jan 06, 2017 | Roomba Vacuums
How do I change schedule on Roomba
go to roomba.com when at there site go to customer care support then to pooduct resources then select a robot roomba,scooba,ect find your sereies 700,600 ect go to documents&manuals then to scheduling roomba then to viewing and deleting schedules follow the steps
Dec 18, 2012 | Roomba iRobot 560/561 Vacuum Cleaner...
My roomba 560 approaches the dock and attempts to dock. However, it never seems to align correctly and backs out. This is a continuous process. It simply will not dock at all. Any suggestions?
Check the connector on your ROOMBA, there is a switch that open the ground when you connect the charger direct to the ROOMBA and a lot of times it get stock and remain open. Using a small screwdriver press the metal plates to force to close.
Oct 08, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba stopped after 45 minutes. does not move. manually placed on docking station...nothing
Sounds like something's dead either with the roomba or the charging station or power supply. Does it charge up if you plug the power supply directly into the roomba, instead of into the charging station? If not, you'll probably have to return it to the place you bought it.
Aug 27, 2010 | iRobot Roomba 560 Robotic Vacuum
560 moves away from dock appears lost
hey gsaban
does it sing 9 beep when it stops ?
if it does, you are facing a known issue of bumper sensor fail.
See this page and other 9 beep threads on FixYa
have fun
Avi
Mar 12, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560: it only spins in one place, then stops & doesn't dock either.
If there's no message its probably a sensor malfunctioning. It might be a cliff sensor, the bump switch, or wheel-drop (left, right, or caster). Try cleaning the sensors and vacuuming things out as a first step.
Nov 22, 2009 | iRobot Roomba 560 Robotic Vacuum
After charging overnight, Roomba only runs about 25 minutes before shutting down with a red light.At this point the battery measures 15.13 volts ( about 1.26 volts per cell ) My hobby experience is that a...
Reset the Roomba by removing it from the charger, then holding "spot" and "dock" for about twelve seconds. When you let go, the unit will play an ascending series of notes. Then recharge it overnight. If the run time is still short, give Customer Support a call-- be sure to have the Roomba with you when you do.
Jun 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba 560, the small red light above the schedule button will not reset and the roomba will not run. The problem started when I the roomba sat dead for 12 hours. I tried the spot dock reset trick with no...
You should start by removing the "belly plate" of the Roomba and simply removing the battery to cycle power to the unit. If that does not solve the problem, it sounds like you need a replacement circuit board for the 560. That's alot trickier since iRobot doesn't like to sell those...they want you to send to them for service.
Your options would be to send to a reputable Roomba repair center like www.protechrobotics.com or you can buy a replacement PCA from places like www.RoboticVacParts.com and replace yourself.
May 07, 2009 | iRobot Roomba 560 Robotic Vacuum
IRobot Roomba (RED) does not start,
Reset your robot by holding down “Spot” and “Dock” together for 10 seconds. this might help
Jan 10, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
2,152 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Marvin
Marvin
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
