Question about Swisher 60" 13 Hp Trailmower #T1360h
Deck belt what size is it also where do i shop for belt
What size belt do i need for a 40" deck
if you have the old belt the size is printed on the back
if the printing is gone then take the old belt to a belt supply shop and they will measure it and sell you the correct belt
If the belt is gone completely then take the mower details along to a mower shop that sells murray mowers and they will have a genuine belt for you
May 02, 2015 | Murray Garden
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How do you replace the belts on a Teac W518R Dual tape deck?
You get oneof the approximate same size or slightly smaller and install it where it is suppose to go. Most shops that are competent will have the belt on hand and if this process seems to advanced, then you are not up to the job. You might have to take the deck out of the unit to work on it. If you are asking this question that would indicate that it might be more than you can do. Some people work on their own equipment only to wreck it as they have no experience in tape deck repair. There is often times a lot more to do than to JUST change a belt.
Apr 28, 2013 | Audio Players & Recorders
Need size of the deck belt toro 212.5 wheel hourse
the size of the belt would change with the size of the deck
Jul 02, 2012 | Toro Garden
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
12 hp roper lawn tractor need belt size for blade drive
take a piece of rope and run it around all the pulleys a mower shop or parts store can match it to that
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What size belt for powr kraft 18/42 industrial commercial twin cylinder automatic hyrostatic dive .need deck belt.
My mower is 18/42 power kraft, limited addition, hydrostatic. I need to replace deck belt because deck belt was bitten by mouse. May I know belt routing and how to replce it. Thank you.
Jan 28, 2012 | Garden
What size belt goes on deck
Under the seat of your mower, there should be a silver and black sticker with a model number on it. It probably looks like 917.123456 . Go to www.searspartsdirect.com and plug in your model number. Follow the links to the deck diagram and find your belt listing. You can even order your part thru them. Craftsman riding mowers are usually made by A.Y.P. and will have fractional belt sizing...that means the belt will be 1/2" x 88.23" or 5/8" x 96.4". Unfortunately this means you will have to get your belt either thru sears, or thru another retailer that offers belts specifically made for your mower. Check with your local repair shop. A general diagram is also on the sears site. That might make it a little easier to reinstall.
Good luck.
Sep 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Swisher 60" 13 Hp Trailmower #T1360h Logo
32 people viewed this question
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
