Question about Shopforbattery Zenith & Lg Ru48sz40 Rear Projector Tv Lamp - High Quality Replacement Lamp
RU-48SZ40 blinking power light - Shopforbattery Zenith & Lg Ru48sz40 Rear Projector Tv Lamp - High Quality Replacement Lamp
DLP Proj TV RU-44SZ61D - Replaced fan. Temp light blinks once when lamp starts and then lamp shuts off. Then temp light blinks once (rest) twice (rest) until the fan turns off. Any ideas?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 12, 2016 | LG RU-44SZ61D 44" TV
Changed the lamp, now it won't power on
are there any lights blinking or solid? red or green?
Nov 03, 2007 | LG RU-44SZ63D Television
Lamp light blinks 5 times
The lamp might be at the end of its life. Change the lamp.
Dec 19, 2012 | LG RU-44SZ61D 44" TV
LG DLP TV temp problem
A temp problem? First check all the fans and make sure they are free from debris or check to see if they are spinning.
Dec 17, 2009 | LG RU-52SZ51D 52" Rear Projection...
Where can I find a Samsung repair center?
LG DLP PROJECTION TV (RU-44SZ63D) Tv light is off (with red light on). When I hit the power on button the red tv light starts blinking. Light continues to blink red then stops blinking and goes back to off (red light on).
Jul 12, 2008 | Televison & Video
No picture-lg ru-52sz51d
Hi lovelace Check your power supply module it needs to be replaced.good luck
Apr 25, 2007 | LG RU-52SZ51D 52" Rear Projection...
Shopforbattery Zenith & Lg Ru48sz40 Rear Projector Tv Lamp - High Quality Replacement Lamp Logo
15 people viewed this question
Top Shopforbattery Televison & Video Experts
Electro Med Services...
Are you a Shopforbattery Televison and Video Expert? Answer questions, earn points and help others
