Question about Dell 22" SP2208WFP Widescreen Flat Panel Monitor
Power light on, no display on screen
The blue power light is steady on but screen is black. I have hooked it up with different cables to a different PC that I know is working, still a black screen. So not a cable problem, not the laptop's problem. Is it dead? None of the menu buttons bring up anything on the screen. Pretty old...thanks.
  • brian hunter Jun 06, 2014
    Hi Valerie Schooley, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
SOURCE: Monitor won't display.
I would suggest that the "Event" that caused the CB to trip has caused ya Monitor to fail.. Probably in the Power Supply, My "Pet" area... lol.. anyway Thats wat I would think. It may even have an internal "Fuse" that has "Blown"?
Posted on Jul 30, 2007
SOURCE: The screen doesn't display anything and the power button is flashing green
http://www.fixya.com/support/t661302-lcd_monitor_green_power_light_blinking
Check out my link, I repaired my flat screen monitor myself.
Posted on Jun 20, 2008
  • 29 Answers
SOURCE: Dell 1701FP monitor - power buttons blinking - no display - no white screen
Solution to a blinking orange power light indicator.
Checking procedures.
1. Check the fuse on the inverter board labeled F1. If it is opened then your inverter board has a problem. That's why the fuse is opened.
2. Remove the white wide cable connecting the main board and inverter board. Next plug the D-sub cable and power adapter and test. If the 2 green light indicators are solid green then your problem is positively coming from your inverter board.
Solution in fixing the inverter board:
In my case, the fuse was opened. So I first resoldered all the legs of the 4 transformers. Eight legs each transformer. Resoldered also the capacitor at the back of the inverter board. Checked the 2 diodes labeled (D3 and D13). One of them was shorted. So replaced it using Radioshack 3A 400piv. It is quite bigger in value but I just want to make sure it can handle the load of current.
Tip in checking a diode, it should always open using a digital tester.
That's it. re-assemble then test it again.
Roan
Triangle Tech Whiz
Posted on Jul 13, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
SOURCE: Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Posted on Aug 21, 2009
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
Screen problem
I have the same problem. rca 26lb30rqd. The red light is on (steady), and when I hit the power button, the blue light comes on for a second, then goes black, w/ no display. Before this happened, the display was extremely bright with ghosting. The picture was un-viewable. Did you every figure out the problem?
Mar 15, 2014 | RCA 26" LCD HDTV/DVD Combo 26LB30RQD - ON...
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
The sreen is black, and the monitor light is orange
This usually indicates an input problem. There are number of things to check:
Make sure the screen is plugged into a working output on the video card - if you can, test the video with a different screen.
Try a different cable; Swap for the same type of cable, or, if available, use a different output method(Such as HDMI).
If using an adapter on the cable, try using a different adapter.
Test the cable on a different display, if possible.
Ultimately, if the video card, cable, and connector are all working, or the display is still not, its likely a bad input board within the display - if you're savvy and have some time to kill, replacement boards cost between 20-70 bucks on ebay.
Feb 10, 2009 | NEC-Mitsubishi Nec Display Solutions...
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
A17w221 goes off automatically with power on
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Mar 25, 2008 | Envision A17W221 Television
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
Dec 30, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
My monitor remains black
well your screens broken mate the only thing you can do is get a new one
Sep 30, 2006 | Amptron CMV-922D 19" Monitor
Dell 22" SP2208WFP Widescreen Flat Panel Monitor Logo
Alun Cox
