Question about RTO Atwood Water Heater - 6 Gal LP
Atwood heater problems
We have fowl smelling water from our atwood water heater. It also puts out soot and doesn't seem to be burning properly
  • bobwestphal Jun 19, 2009
    Does the anode rod need to be replaced or should I just leave it out?
    Thenks!!
The smell is from the (anode rod not sure of this term is exact) in the water hater. Smells like rotten eggs. You have to remove the rod in the top of the water heater. This will void the warranty of the heater. The soot is due to flame adjustment. this should be done by a professional.
Posted on Jun 18, 2009
  • rickjason Jun 19, 2009
    When you pull the rod out it will be part of the plug you pull from the top. Just cut it off and install the plug. The function of the rod is to collect minerals from the water so you don't get sediment in the bottom of the tank.
Flame burning too orange
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
Mar 27, 2014 | Water Heaters
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
Heavy soot on vent and up camper side
The normal problem is mud wasps plugging up the burner. you need to remove the gburner and clean it out
Oct 09, 2012 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood hot water heater in a Bounder motorhome. When I turn on the switch to fire up the electronic ignition, it instantly blows the 12v fuse. An inspection of the unit shows wiring with melted...
My guess is that you may have or have had a spider web or other debris in burner tube that caused flame to back up, thus burning some wiring but, have someone experienced check it and clean it. The wiring if not burned too bad may be able to be repaired/spliced.
Jul 03, 2011 | RTO Atwood Water Heater - 6 Gal LP
I HAVE A 10 GALLON ATWOOD WATER HEATER IN A PARK HOME THE PILOT LIHTS FINE AND STARTS THE GAS OK WATER IS NOT GETTING HOT IT LOOKS LIKE SOME OF THE FLAME IS COMING OUT OF THE HEAT TUBE GETTING CARBON ON...
I would definitely have the burner tube cleaned and adjusted if necessary. Sounds like a possible spider web in the tube, as well as have heat chamber blown out with compressed air if at all possible to remove soot build up. Stand back when blowing it out, or you"ll be covered in soot.
You can buy a long brush for cleaning barbecue burners, that work well.
Feb 11, 2011 | RTO Atwood Water Heater - 6 Gal LP
ON MY ATWOOD WATERHEATER IT LIGHTS BUT PRODUCES A LOT OF SOOT AND DOES NOT SEEM TO FIRE UP LIKE IT SHOULD
You need to start by cleaning burner tube and pilot intake , sounds like spiders have probably spun a web in there. If flame is yellowish, it's not getting enough air. You can buy a barbecue burner brush, long and flexible, and run it through burner tube to clean out web, and if pilot is yellow as well, there is a small hole in side of fitting where it attaches up near burner that needs to be cleaned out with paper clip or even better, compressed air. After cleaning burner, adjust air shutter to get nice blue flame, with just a hint of yellow at tip. The idea there is to get blue flame, but not a roaring flame that is jumping off the burner. A spider web in there will usually allow propane through, but restricts air mixture, thus causing yellow flame (rich mixture) and soot to build up.
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
My pilot flame is too high . What could be causing this ?
If it's an Atwood and just recently started burning a yellow, higher flame, look closely at side of fitting where the pilot tube is attached to mounting bracket. You should see a very small hole in the side of that fitting. Take a paper clip, or something as small in diameter, and poke around inside that hole to clean it out, or shut pilot off, and use compressed air, to blow into it, to clean it out. Now re-lite your pilot and see if you have a nice blue flame now. That little hole is your air mixture for the pilot and sometimes debris clogs it, thus causes (rich mixture) yellow/red flame, which will also cause soot build-up in the chamber, or even on outside cover. Let me know if that cures it.
May 09, 2010 | RTO Atwood Water Heater - 6 Gal LP
Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
I have an atwood water heater that won't stay light
I am having the same problem. Is your water heater a power vent?
May 02, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood Water Heater - 6 Gal LP Logo
274 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
