Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Jet pump does not pump water
I had a leak on the water pipe going into the well, it has been fixed and no more leaks.I then primed the pump, the pump is fully primed with lost of pressure , but its not pumping water. Do i continue to prime the pump?
    Problem Solver:
  • 10 Answers
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
Posted on Oct 24, 2009
  • 21 Answers
Do yo have a two line system
Posted on Jun 25, 2009
How deep water for pump 63407
you have to say what pump you are using
if it is a submersible pump it could be jammed impeller blades and a blown circuit breaker
if it is a centrifugal pump and is not a jet assist pump then the lift head is exceeded to lift water to the pump from suction Most pumps of this type have a max head lift of 10 ft with a 2" suction pipe as the weight of water is too much to lift A jet assist pump is a better option for up to 20 ft
next is the pump primed now if it was pumping before as a bad foot valve will leak the water out of the pump so that it requires priming before it will work
Jul 13, 2017 | Plumbing
How do I prime my flotec 4022 pump
A number of Flotec pump manuals are available here: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx . The site lists a FP4022-10 pump with the direct link to the manual here: http://www.flotecpump.com/resources/images/514.pdf .
For this type of pump, there should be a priming plug or priming tee. Remove the plug (or tee) and pour water into the pump. Keep adding water until the pump and all of the piping to the well is full of water. If a priming plug or tee was also added on the suction side of the pump, open that section and fill all of the piping on the suction side with water. Replace the plugs/tees then open a faucet in the house. Start the pump. After 2-3 minutes, turn off the pump if no water has come through the unit. Add more water through the priming plug or tee (or multiple plugs and tees). Then repeat closing the priming ports and start the pump after opening a faucet. Once the pump is actually pumping water, turn off the open faucet. Wait for the pump to shut off once it reaches full pressure. Open one or two faucets to check that the pump is properly sensing the pressure changes and maintaining system water pressure.
If the unit didn't pull water from the well, check the piping for air leaks. See the full trouble-shooting guide in the manual. Page 9 has the priming information and page 10 has the trouble-shooting guide.
I hope this helps.
Aug 27, 2016 | Flotec Plumbing
HOW can I tell if a Goulds jet pump needs replacement?
pull the foot valve as it takes very little to allow the water to drain back out. Personally I would replace all pipes in the hole with heavy duty /high pressure plastic agricultural irrigation pipes
Aug 17, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Pump does not pump anything. motor is running and getting hot, no water being pumped. i have to prime this stupid thing?
If you are trying to draw water from a lower place, you may have lost prime. It is also possible there is a reason for this loss of prime, maybe a leak on the suction piping. Remove some fitting on or near the discharge of the pump, fill the body completely with water. If it goes in, fill the entire suction piping with water, too. Open a faucet nearby, turn on the pump and wait up to 5 minutes. It should spit and sputter, sound will change, some water will discharge, but eventually, you should get steady flow.
If you lose prime again, look for leaks in the suction piping from the inlet of the pump to where the piping goes into the ground.
Your FixYa Texpert,
Gary
Aug 16, 2011 | Flotec Corrosion Resistant Shallow Well...
Hello, Our Flotec Shallow well Jet is installed in our basement a distance ( perhaps 50 feet or so from the well casing outside in the yard. The pump was installed as a replacement for a worn jet pump...
Hi, Tom, W/D here.
You shouldn't really need a check valve as the foot valve is in effect a check valve.
Next time that you are near the pump when it kicks on and you are using no water, let it achieve full pressure and kick off. Close the discharge valve, isolating the pump and suction line. Watch the pressure gauge. If the pressure falls, you either have a leak in the suction line, possibly a leak at the well head (sucking air), a leak in the casing riser pipe or bad foot valve.
If the pressure holds steady, open the discharge valve and note the pressure. If it falls immediately upon opening the valve, the leak would be on the house side if the pump. Look then for any sources of water usage (ice maker, drips in the tub, water from the pop-off valve at the water heater, etc.).
Best regards, and good luck.
If I can be of any further assistance, please post back.
--W/D--
Jan 22, 2011 | Flotec Corrosion Resistant Shallow Well...
I replaced old pump w/ Flotec 1/2HP FP4012 and replaced old pressure tank w new 35gal tank. Pump primed but cycles on-off every minute constantly even w/ no water turned on. Goes to 50PSI, loses pressure...
The water and therefore the pressure has to be going somewhere. If you are sure that there are no leaks in the house or outside, then the water is going back into the well. There is a check valve either in the suction line of the pump between the top of the well and the pump or down in the well.
If this check valve fails, it allows water to go the wrong way and back to the well. The result is that you lose pressure.
Secondly, you have to be sure that there are no air leaks between the top of the well and the inlet to the check valve. Leaks in that piping will make repriming difficult.
Write back with more and I'll try to help more.
Gary
Leaky pump on jetted tub
You might just need to tighten the bolts. If that doesn't fix it you can dismantle it and replace the O-ring. Be sure to lightly coat the new ring with silicone grease before installing it. A pool supply store should be able to help you with the right part.
May 03, 2010 | Home
We have a well that has recently lost all water pressure. We have now replaced the points, the switch, the valves, and the pipe from the pump to the tank. We have bypassed the underground piping to see if...
What kind of pump is it? If it is a jet pump, it may need to be primed or the foot valve in the well could be blocked with rust or dirt. On a shallow well or jet pump, check it for suction side leaks. turn it off, and see if water seeps out of any of the joints. A small amount of air seeping in will make the pump airbound and keep it from building pressure.
Mar 07, 2010 | Plumbing
My Jet Pump Looses it's prime at night.
I assume the pump is not running at night. If the pump is higher than the pool, and the inlet and outlet to the pool are both under water, then you have a small leak. This could be allowing the water to leak out of the line. Or, if the leak is higher than the pool surface it is allowing air to leak into the line, which allows the prime to run down into the pool. If you found this useful, please vote. Thanks.
Feb 16, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
PUMP LOSES PRIME OVERNIGHT. ALL CONNECTIONS, ADAPTORS, AND CHECK VALVES HAVE BEEN REPLACED TO ELIMINATE ANY AIR LEAKS. SEEMS LIKE THERE IS EITHER A LEAK UNDERGROUND IN THE SUPPLY LINE OR A PROBLEM WITH THE...
Yes, any air leak could allow the pumps system to draw air in to it. This could happen through a gasket or the mechanical seal although if the foot valve is in good shape and there are no leaks within the piping system the pump should hold prime. My guess is there is some type of leak within the suction piping that is creating a slight vacuum. A vacuum leak, even a small amount, is very powerful at drawing air in to it. My first thoughts are to insure the suction piping and its components are all proper.
I hope this may have helped,
Tom
Oct 07, 2009 | Jet Plumbing
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
831 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
